Aller au contenu principal
Omaker M4 Port Cover Replacement
Ce dont vous avez besoin
  1. Omaker M4 Port Cover Replacement, Back Case: étape 1, image 1 de 1
    • Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
  2. Omaker M4 Port Cover Replacement: étape 2, image 1 de 2 Omaker M4 Port Cover Replacement: étape 2, image 2 de 2
    • Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
  3. Omaker M4 Port Cover Replacement: étape 3, image 1 de 2 Omaker M4 Port Cover Replacement: étape 3, image 2 de 2
    • Use a magnet to remove the screws after unscrewing them and place them aside.
  4. Omaker M4 Port Cover Replacement: étape 4, image 1 de 1
    • Carefully remove the back cover without breaking the battery wire.
  5. Omaker M4 Port Cover Replacement: étape 5, image 1 de 2 Omaker M4 Port Cover Replacement: étape 5, image 2 de 2
    • Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
    • The battery is still attached to the back cover.
  6. Omaker M4 Port Cover Replacement, Motherboard: étape 6, image 1 de 2 Omaker M4 Port Cover Replacement, Motherboard: étape 6, image 2 de 2
    • Remove the mic wire by carefully pulling the plug out of the socket.
  7. Omaker M4 Port Cover Replacement: étape 7, image 1 de 1
    • Remove the speaker wire by carefully pulling the plug out of the socket on the motherboard.
  8. Omaker M4 Port Cover Replacement: étape 8, image 1 de 2 Omaker M4 Port Cover Replacement: étape 8, image 2 de 2
    • Use Phillips PH00 screwdriver to remove the three screws holding the motherboard in place.
  9. Omaker M4 Port Cover Replacement: étape 9, image 1 de 2 Omaker M4 Port Cover Replacement: étape 9, image 2 de 2
    • Remove the screws using the screwdriver.
    • Since the screws that hold the motherboard in place are smaller, the screwdriver is able to pick them up.
  10. Omaker M4 Port Cover Replacement: étape 10, image 1 de 2 Omaker M4 Port Cover Replacement: étape 10, image 2 de 2
    • Carefully remove the motherboard with your hand by lifting it from the device.
  11. Omaker M4 Port Cover Replacement, Port Cover: étape 11, image 1 de 2 Omaker M4 Port Cover Replacement, Port Cover: étape 11, image 2 de 2
    • Separate the port cover from the device using your hands.
  12. Omaker M4 Port Cover Replacement: étape 12, image 1 de 1
    • Orient the device so the port cover is on your left.
  13. Omaker M4 Port Cover Replacement: étape 13, image 1 de 2 Omaker M4 Port Cover Replacement: étape 13, image 2 de 2
    • Using Tweezers, pinch the larger part of the stem
  14. Omaker M4 Port Cover Replacement: étape 14, image 1 de 1
    • Use your left hand to pull while at the same time use the tweezers to compress the stem, carefully remove the port cover from the device.
2 autres ont terminé cette réparation.
Obaida Matar
Membre depuis le 02/17/16
119 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 2-2, Sullivan Spring 2016 Membre de l'équipe USF Tampa, Team 2-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G2
3 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 365
