Aller au contenu principal
One Education Infinity Heatsink Replacement
Ce dont vous avez besoin
  1. One Education Infinity Heatsink Replacement, Back Case: étape 1, image 1 de 3 One Education Infinity Heatsink Replacement, Back Case: étape 1, image 2 de 3 One Education Infinity Heatsink Replacement, Back Case: étape 1, image 3 de 3
    • Always power off your device before beginning disassembly.
    • Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
  2. One Education Infinity Heatsink Replacement: étape 2, image 1 de 2 One Education Infinity Heatsink Replacement: étape 2, image 2 de 2
    • Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
  3. One Education Infinity Heatsink Replacement: étape 3, image 1 de 3 One Education Infinity Heatsink Replacement: étape 3, image 2 de 3 One Education Infinity Heatsink Replacement: étape 3, image 3 de 3
    • Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
    • Lift the back case off of the device.
    • Removing the back may create a loud snapping noise.
  4. One Education Infinity Heatsink Replacement, Battery: étape 4, image 1 de 3 One Education Infinity Heatsink Replacement, Battery: étape 4, image 2 de 3 One Education Infinity Heatsink Replacement, Battery: étape 4, image 3 de 3
    • There may be black tape inside your device covering components or holding down wires. This tape is unimportant for the function of the device, and can be removed.
    • Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
  5. One Education Infinity Heatsink Replacement: étape 5, image 1 de 3 One Education Infinity Heatsink Replacement: étape 5, image 2 de 3 One Education Infinity Heatsink Replacement: étape 5, image 3 de 3
    • Wedge a plastic spudger underneath the battery from the upper edge and slide it carefully along the length of the battery to separate it from the case.
    • There is a mild adhesive holding down the battery. Take care not to puncture or excessively bend the battery while freeing it from the adhesive.
    • Lift the battery out from the internal case.
  6. One Education Infinity Heatsink Replacement, Heatsink: étape 6, image 1 de 2 One Education Infinity Heatsink Replacement, Heatsink: étape 6, image 2 de 2
    • Remove the eight 2.8 mm screws from the heatsink with a Phillips #00 screwdriver.
  7. One Education Infinity Heatsink Replacement: étape 7, image 1 de 3 One Education Infinity Heatsink Replacement: étape 7, image 2 de 3 One Education Infinity Heatsink Replacement: étape 7, image 3 de 3
    • Insert the tip of a spudger into the small gap along the right side edge of the heatsink and pry upward to free it from the clips.
  8. One Education Infinity Heatsink Replacement: étape 8, image 1 de 1
    • Lift the heatsink up from the motherboard.
Austin Blakely
Membre depuis le 03/11/19
19 855 Réputation
53 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
141 membres
17 893 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 204
