Aller au contenu principal
One Education Infinity Speakers Replacement
Ce dont vous avez besoin
  1. One Education Infinity Speakers Replacement, Back Case: étape 1, image 1 de 3 One Education Infinity Speakers Replacement, Back Case: étape 1, image 2 de 3 One Education Infinity Speakers Replacement, Back Case: étape 1, image 3 de 3
    • Always power off your device before beginning disassembly.
    • Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
  2. One Education Infinity Speakers Replacement: étape 2, image 1 de 2 One Education Infinity Speakers Replacement: étape 2, image 2 de 2
    • Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
  3. One Education Infinity Speakers Replacement: étape 3, image 1 de 3 One Education Infinity Speakers Replacement: étape 3, image 2 de 3 One Education Infinity Speakers Replacement: étape 3, image 3 de 3
    • Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
    • Lift the back case off of the device.
    • Removing the back may create a loud snapping noise.
  4. One Education Infinity Speakers Replacement, Battery: étape 4, image 1 de 3 One Education Infinity Speakers Replacement, Battery: étape 4, image 2 de 3 One Education Infinity Speakers Replacement, Battery: étape 4, image 3 de 3
    • There may be black tape inside your device covering components or holding down wires. This tape is unimportant for the function of the device, and can be removed.
    • Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
  5. One Education Infinity Speakers Replacement: étape 5, image 1 de 3 One Education Infinity Speakers Replacement: étape 5, image 2 de 3 One Education Infinity Speakers Replacement: étape 5, image 3 de 3
    • Wedge a plastic spudger underneath the battery from the upper edge and slide it carefully along the length of the battery to separate it from the case.
    • There is a mild adhesive holding down the battery. Take care not to puncture or excessively bend the battery while freeing it from the adhesive.
    • Lift the battery out from the internal case.
  6. One Education Infinity Speakers Replacement, Solid State Drive: étape 6, image 1 de 3 One Education Infinity Speakers Replacement, Solid State Drive: étape 6, image 2 de 3 One Education Infinity Speakers Replacement, Solid State Drive: étape 6, image 3 de 3
    • Use a Phillips #00 screwdriver to remove the single 2mm black screw from the SSD.
  7. One Education Infinity Speakers Replacement: étape 7, image 1 de 3 One Education Infinity Speakers Replacement: étape 7, image 2 de 3 One Education Infinity Speakers Replacement: étape 7, image 3 de 3
    • Grab the SSD with your fingers and slide it slowly to the right and out of its port.
  8. One Education Infinity Speakers Replacement, Motherboard: étape 8, image 1 de 2 One Education Infinity Speakers Replacement, Motherboard: étape 8, image 2 de 2
    • Using your fingers, carefully pull the two ribbon cable locking clips out from their ports.
  9. One Education Infinity Speakers Replacement: étape 9, image 1 de 1
    • Using your fingers, carefully lift up the black tab and then unplug the gold ribbon cable.
  10. One Education Infinity Speakers Replacement: étape 10, image 1 de 1
    • Using a spudger, carefully unplug the black and grey wires by popping them up off the wireless card.
  11. One Education Infinity Speakers Replacement: étape 11, image 1 de 1
    • Using your fingers, carefully unplug the two speaker wires from the motherboard.
  12. One Education Infinity Speakers Replacement: étape 12, image 1 de 2 One Education Infinity Speakers Replacement: étape 12, image 2 de 2
    • Using your fingers or an iFixit opening tool, carefully lift the black tab on top of the ZIF connector and remove the ribbon cable.
  13. One Education Infinity Speakers Replacement: étape 13, image 1 de 1
    • Using your fingers, carefully lift up the black tab and then unplug the blue ribbon cable.
  14. One Education Infinity Speakers Replacement: étape 14, image 1 de 2 One Education Infinity Speakers Replacement: étape 14, image 2 de 2
    • Using a Phillips #00 screwdriver, remove the single 4 mm silver screw from beneath the ribbon cable.
    • Using a Phillips #00 screwdriver, remove the two 2.5 mm black screws.
    • Using your fingers, carefully lift the motherboard out of the internal panel.
  15. One Education Infinity Speakers Replacement, Speakers: étape 15, image 1 de 1
    • Using a Phillips #00 screwdriver, remove the four 2mm silver screws.
  16. One Education Infinity Speakers Replacement: étape 16, image 1 de 2 One Education Infinity Speakers Replacement: étape 16, image 2 de 2
    • Peel back the black tape.
    • Using your fingers, carefully lift the metal plate out of the internal panel.
  17. One Education Infinity Speakers Replacement: étape 17, image 1 de 3 One Education Infinity Speakers Replacement: étape 17, image 2 de 3 One Education Infinity Speakers Replacement: étape 17, image 3 de 3
    • Using your fingers, carefully lift the two speakers out of the internal panel.
Jacob Barnes
Membre depuis le 10/10/19
193 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S11-G4, Regan Fall 2019 Membre de l'équipe Cal Poly, Team S11-G4, Regan Fall 2019
CPSU-REGAN-F19S11G4
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 178
