Introduction
This guide will detail how to replace the display assembly in the One Education Infinity:One laptop. After completion of this guide, the digitizer and screen will be separated to allow for replacement of either component.
Ce dont vous avez besoin
Insert a Jimmy or other prying tool into the seam between the screen and back case.
Trace around the edges until all clips are released.
Lift the back case away from the tablet.
Use a spudger to release the speaker wires by pushing the bundled cabled connector away from the motherboard.
Use a spudger to disconnect the black bundled cable connector from the motherboard.
Use ESD safe tweezers to disconnect the antenna from the motherboard.
Use a spudger to flip up the black flap on the camera's ZIF connector.
Pull the ribbon cable straight out of the connector.
