Introduction
Before you replace your screen you will need to take out the battery.
Ce dont vous avez besoin
Make sure that your phone is turned off before proceeding
Use an opening pick, your thumbnail, or a spudger to gently pry off the external casing
Outil utilisé dans cette étape :Tweezers$4.99
Find and carefully remove all 6 rubber screw covers with the tweezers.
Unscrew all 18 screws from the mid frame.
Use the spudger tool to pry up the top connection of the charging port.
Follow the cable with the spudger and slowly pry it up from the adhesive holding it down.
Stop at the next connection.
Locate two connections at the bottom of the phone.
Using a spudger, carefully bend the connections up and towards the top of the phone.
65 autres ont terminé cette réparation.
29 commentaires
Screen is available on internet but without frame and buttons. I bought one of those so the only pb i had was to separate capacitive buttons and fingerprint scanner from the screen. i had to separate the black plastic frame from the screen too. It takes me around 2 hours to do it but now my OP2 works with a brand new screen. Changing screen on OnePlus2 is doable and cost around 100€ but you have to be careful and patient.
Is the screen working properly??
It's the glue on the back of the screen or on the frame? Do you need to apply new glue?
krugern -
Hi, can you recommend the place where you bought your screen?
