Introduction
This guide shows how to remove and replace the fingerprint scanner/home button for the OnePlus 3. This requires removing the daughterboard. The hardest part of the guide is getting the frame clips free.
Some guide images will show the battery and an interconnect flex cable already removed from the phone. You do not need to remove these for the fingerprint scanner procedure.
Ce dont vous avez besoin
Insert a SIM eject tool, bit, or straightened paperclip into the hole located between the SIM card slot and the power button.
Press firmly to eject the SIM card tray.
Display panel seam: This seam is part of the display assembly. Do not pry at this seam, or you will separate and damage the display panel.
Frame seam: This is where the plastic frame meets the back cover. It is recessed into the back cover. Only pry at this seam.
There are fourteen clips that hold the frame against the rear case. Be aware of their location as you pry the back cover off in the following steps.
With the bottom and left edge of the phone freed, gently wiggle the frame to release the top and right edge clips.
Lift the screen up and remove it.
Align the top edge of the frame to the back cover and ensure that the top clips slip into place.
Squeeze along the long edges of the phone to snap the remaining clips into place.
Use the point of a spudger to pry up and disconnect the battery connector from its socket, located above the top right corner of the battery pack.
Bend the connector away from the socket to prevent accidental contact.
Remove the 3 mm Phillips screw securing the cable bracket.
Remove the cable bracket.
Use the point of a spudger to pry up and disconnect the capacitative buttons connector from its socket on the daughterboard, which is located below the battery.
Repeat the process to disconnect the fingerprint scanner connector from its socket on the daughterboard.
Slide the edge of an opening tool underneath the fingerprint scanner cover near the bottom edge of the frame and pry up.
Remove the fingerprint scanner cover.
Repair didn’t go as planned? Check out our OnePlus 3 Answers community for troubleshooting help.
2 autres ont terminé cette réparation.
