Introduction
The OnePlus 6 smartphone might need a speaker replacement for several reasons, like water damage or wear from regular use. The internal speaker plays sound out loud when no external audio output is present. If the device will not play sound or sounds come out distorted, a speaker replacement may be required.
As this guide will help everyday users replace a part within the device, they should be aware of potential damage from using the heat gun. While working on the inside of the mobile phone, users should be careful not to damage any delicate parts.
Ce dont vous avez besoin
Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
Repeat until the back panel is fully released.
Grip the green tab connected to the battery and pull the battery directly up and out.
Use a Phillips #000 screwdriver to remove the eight screws.
Carefully lift the speaker up and out of the chassis.
Enjoy your new speaker!
