Aller au contenu principal
OnePlus 7 Pro Battery Cover Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. OnePlus 7 Pro Battery Cover Replacement, OnePlus 7 Pro Battery Cover  Replacement: étape 1, image 1 de 3 OnePlus 7 Pro Battery Cover Replacement, OnePlus 7 Pro Battery Cover  Replacement: étape 1, image 2 de 3 OnePlus 7 Pro Battery Cover Replacement, OnePlus 7 Pro Battery Cover  Replacement: étape 1, image 3 de 3
    • Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the top edge of the phone.
    • Press gently to eject the SIM tray.
    • Remove the SIM card tray from the device.
    • To reinsert the SIM card tray, orient the SIM card with the gold contacts facing up and the notch to the bottom right. Reinsert the SIM card by pressing the card gently into the SIM tray slot.
  2. OnePlus 7 Pro Battery Cover Replacement: étape 2, image 1 de 2 OnePlus 7 Pro Battery Cover Replacement: étape 2, image 2 de 2
    • Use a heat gun to lightly heat the edges of the back to soften the adhesive that connects the back cover to the rest of the frame.
    • Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
    • Be careful not to overheat the device –the OLED display, battery and other internal parts can be damaged by excessive heat. Approximately one minute should be enough to soften the adhesive.
    • An iFixit iOpener, hairdryer, or hot plate can also be used to heat the edges. See the iOpener Heating guide for instructions on using the iOpener.
  3. OnePlus 7 Pro Battery Cover Replacement: étape 3, image 1 de 3 OnePlus 7 Pro Battery Cover Replacement: étape 3, image 2 de 3 OnePlus 7 Pro Battery Cover Replacement: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    J'achète
    • Apply a suction cup to the lower portion of the phone's backing and pull firmly to create a crack between the back cover and the rest of the phone.
    • Insert a Jimmy tool, opening pick, or plastic card under the edge of the back cover.
  4. OnePlus 7 Pro Battery Cover Replacement: étape 4, image 1 de 3 OnePlus 7 Pro Battery Cover Replacement: étape 4, image 2 de 3 OnePlus 7 Pro Battery Cover Replacement: étape 4, image 3 de 3
    • Use a plastic card or Jimmy tool to slice around the phone's seam, cutting through the adhesive.
  5. OnePlus 7 Pro Battery Cover Replacement: étape 5, image 1 de 2 OnePlus 7 Pro Battery Cover Replacement: étape 5, image 2 de 2
    • Remove the phone's back cover.
    • If you have replacement adhesive strips, remove any remaining adhesive from the device frame using the Jimmy tool.
  6. OnePlus 7 Pro Battery Cover Replacement: étape 6, image 1 de 3 OnePlus 7 Pro Battery Cover Replacement: étape 6, image 2 de 3 OnePlus 7 Pro Battery Cover Replacement: étape 6, image 3 de 3
    J'achète
    • Use a pair of tweezers to lift up the piece of black tape covering the laser autofocus and flash flex cable.
    • Use a pair of tweezers to lift and remove the covering on the laser autofocus and flash flex cable.
  7. OnePlus 7 Pro Battery Cover Replacement: étape 7, image 1 de 1
    • Use the flat end of a spudger to disconnect the laser autofocus and flash flex cable.
  8. OnePlus 7 Pro Battery Cover Replacement: étape 8, image 1 de 2 OnePlus 7 Pro Battery Cover Replacement: étape 8, image 2 de 2
    • Peel off the adhesive cover for the new battery cover.
To reassemble your device, replace the battery cover and follow these instructions in reverse order.
9 autres ont terminé cette réparation.
Selena
Membre depuis le 12/15/19
2 686 Réputation
14 tutoriels rédigés
Un commentaire
Could this be used and adapted to replace the charging port?
S. S. - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 19
30 derniers jours : 102
Total : 9,377
