Aller au contenu principal
Pour réparer ensemble - Je crée un compte
OnePlus 8 Light Sensor Replacement
Ce dont vous avez besoin
  1. OnePlus 8 Light Sensor Replacement, Heat the rear glass: étape 1, image 1 de 1
    • Power off your phone and unplug any cables.
    • Heat an iOpener and apply it to the rear glass for two minutes.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and internal battery, so proceed with care.
    Demander à FixBot
    Ajouter un commentaire
  2. OnePlus 8 Light Sensor Replacement, Insert an opening pick: étape 2, image 1 de 3 OnePlus 8 Light Sensor Replacement, Insert an opening pick: étape 2, image 2 de 3 OnePlus 8 Light Sensor Replacement, Insert an opening pick: étape 2, image 3 de 3
    • Apply a suction handle to the center of the bottom edge of the rear glass, as close to the edge as possible.
    • If your display is badly cracked, cover it with a layer of clear packing tape to help the suction cup adhere. Alternatively, you can pull using very strong tape instead of a suction cup. If all else fails, try supergluing the suction cup to the broken screen.
    • Pull up on the suction handle with strong, steady force to create a gap between the rear glass and frame.
    • Insert an opening pick into the gap.
    Demander à FixBot
  3. OnePlus 8 Light Sensor Replacement, Slice the bottom edge adhesive: étape 3, image 1 de 3 OnePlus 8 Light Sensor Replacement, Slice the bottom edge adhesive: étape 3, image 2 de 3 OnePlus 8 Light Sensor Replacement, Slice the bottom edge adhesive: étape 3, image 3 de 3
    • Slide the opening pick to the bottom right corner to slice the adhesive securing the rear glass.
    • Leave the opening pick in the bottom right corner to prevent the adhesive from resealing.
    Demander à FixBot
  4. OnePlus 8 Light Sensor Replacement: étape 4, image 1 de 3 OnePlus 8 Light Sensor Replacement: étape 4, image 2 de 3 OnePlus 8 Light Sensor Replacement: étape 4, image 3 de 3
    • Insert a second opening pick under the bottom edge of the rear glass, into the gap you just created.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
    Demander à FixBot
  5. OnePlus 8 Light Sensor Replacement, Slice the left edge adhesive: étape 5, image 1 de 3 OnePlus 8 Light Sensor Replacement, Slice the left edge adhesive: étape 5, image 2 de 3 OnePlus 8 Light Sensor Replacement, Slice the left edge adhesive: étape 5, image 3 de 3
    • If you have trouble slicing, reheat the iOpener and apply it to the edge for two minutes to soften the adhesive.
    • Insert a third opening pick under the bottom left corner of the rear glass.
    • Slide the opening pick up the left edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
    Demander à FixBot
  6. OnePlus 8 Light Sensor Replacement, Slice the top edge adhesive: étape 6, image 1 de 3 OnePlus 8 Light Sensor Replacement, Slice the top edge adhesive: étape 6, image 2 de 3 OnePlus 8 Light Sensor Replacement, Slice the top edge adhesive: étape 6, image 3 de 3
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    Demander à FixBot
  7. OnePlus 8 Light Sensor Replacement, Slice the right edge adhesive: étape 7, image 1 de 3 OnePlus 8 Light Sensor Replacement, Slice the right edge adhesive: étape 7, image 2 de 3 OnePlus 8 Light Sensor Replacement, Slice the right edge adhesive: étape 7, image 3 de 3
    • Insert a fifth opening pick under the top right corner of the rear glass.
    • Slide the opening pick down the right edge to slice the remaining adhesive.
    Demander à FixBot
  8. OnePlus 8 Light Sensor Replacement, Remove the rear glass: étape 8, image 1 de 3 OnePlus 8 Light Sensor Replacement, Remove the rear glass: étape 8, image 2 de 3 OnePlus 8 Light Sensor Replacement, Remove the rear glass: étape 8, image 3 de 3
    • Remove the rear glass.
    • If the rear glass still feels stuck to the frame, slide an opening pick around the entire perimeter until the rear glass separates completely.
    • During reassembly:
    • Secure the rear glass with pre-cut adhesive or double-sided adhesive tape.
    • After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond.
    Demander à FixBot
  9. OnePlus 8 Light Sensor Replacement, Unfasten the motherboard cover: étape 9, image 1 de 1
    Outil utilisé dans cette étape :
    • A white sticker may cover a screw on the right edge of the motherboard cover. Pierce through it with the tip of your screwdriver or use tweezers to remove it.
    • Use a Phillips screwdriver to remove the eleven 3.3 mm-long screws securing the motherboard cover.
    Demander à FixBot
  10. OnePlus 8 Light Sensor Replacement, Pry up the motherboard cover: étape 10, image 1 de 3 OnePlus 8 Light Sensor Replacement, Pry up the motherboard cover: étape 10, image 2 de 3 OnePlus 8 Light Sensor Replacement, Pry up the motherboard cover: étape 10, image 3 de 3
    • The motherboard cover is secured by tight clips.
    • Insert the flat end of a spudger under the center of the motherboard cover's bottom edge.
    • Twist the spudger to release the clips.
    • Lever the motherboard cover up until you can grip it with your fingers.
    Demander à FixBot
  11. OnePlus 8 Light Sensor Replacement, Remove the motherboard cover: étape 11, image 1 de 2 OnePlus 8 Light Sensor Replacement, Remove the motherboard cover: étape 11, image 2 de 2
    • Remove the motherboard cover.
    Demander à FixBot
  12. OnePlus 8 Light Sensor Replacement, Disconnect the battery cable: étape 12, image 1 de 2 OnePlus 8 Light Sensor Replacement, Disconnect the battery cable: étape 12, image 2 de 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket on the bottom left corner of the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    Demander à FixBot
  13. OnePlus 8 Light Sensor Replacement, Rear Camera: étape 13, image 1 de 2 OnePlus 8 Light Sensor Replacement, Rear Camera: étape 13, image 2 de 2
    • Disconnect the antenna cable connector on the right, using tweezers.
    • Disconnect the antenna cable connector on the left using tweezers.
    Demander à FixBot
  14. OnePlus 8 Light Sensor Replacement: étape 14, image 1 de 3 OnePlus 8 Light Sensor Replacement: étape 14, image 2 de 3 OnePlus 8 Light Sensor Replacement: étape 14, image 3 de 3
    • Use an opening tool to gently pry and disconnect the three camera press connectors.
    Demander à FixBot
  15. OnePlus 8 Light Sensor Replacement: étape 15, image 1 de 1
    • Remove the rear camera.
    Demander à FixBot
  16. OnePlus 8 Light Sensor Replacement, Motherboard: étape 16, image 1 de 2 OnePlus 8 Light Sensor Replacement, Motherboard: étape 16, image 2 de 2
    • Use an opening tool to pry up and disconnect the front camera press connector.
    • Remove the front camera.
    Demander à FixBot
  17. OnePlus 8 Light Sensor Replacement: étape 17, image 1 de 3 OnePlus 8 Light Sensor Replacement: étape 17, image 2 de 3 OnePlus 8 Light Sensor Replacement: étape 17, image 3 de 3
    • Use an opening tool to pry up and disconnect each of the three press connectors attached to the motherboard.
    Demander à FixBot
  18. OnePlus 8 Light Sensor Replacement: étape 18, image 1 de 1
    • Remove the motherboard by carefully pryinng it out with the opening tool, lifting the battery out to make removal easier.
    Demander à FixBot
  19. OnePlus 8 Light Sensor Replacement, Light Sensor: étape 19, image 1 de 1
    • Insert an opening tool into the gap between the light sensor and chassis.
    • Pry the light sensor up and out.
    Demander à FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Jose Reyes
Membre depuis le 09/19/24
73 Réputation
1 tutoriel rédigé
Équipe
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 30
Total : 286
