Aller au contenu principal
Pour réparer ensemble - Je crée un compte
OnePlus 8 Pro Battery Replacement
Ce dont vous avez besoin
  1. OnePlus 8 Pro Battery Replacement, Battery: étape 1, image 1 de 1
    • Heat up the back edge of the phone with the iOpener / any HotPack.
    • Start with a long edge as it is easier to open the back cover in the next step.
    • You may also use a hair dryer or heat gun to heat the adhesive.
    • Be careful not to overheat the phone - the screen and internal battery are susceptible to heat damage.
    Demander à FixBot
    Ajouter un commentaire
  2. OnePlus 8 Pro Battery Replacement: étape 2, image 1 de 1
    • Insert the opening pick in the middle of the phone where you heated it. Slide it along the edge to cut through the adhesive.
    • This can be a bit tricky, don't use any sharp objects as you can damage the case. It's reccomended that you use a plastic wedge tool such as the one by iFixit, as it has a thicker ledge to prevent you from slicing too far in.
    • If it does not work, try heating the edge again.
    • Don't insert the opening pick too far. There are no flex cables in the way, but the wireless charging coil could be damaged.
    Demander à FixBot
  3. OnePlus 8 Pro Battery Replacement: étape 3, image 1 de 2 OnePlus 8 Pro Battery Replacement: étape 3, image 2 de 2
    • Leave the opening picks once you managed to open one side.
    • Use heat on the next edge to open it.
    • Repeat steps 2 and 3 for all four edges.
    Demander à FixBot
  4. OnePlus 8 Pro Battery Replacement: étape 4, image 1 de 1
    • Remove these screws (Phillips 00).
    • Remove this Phillips 00 screw. You can remove the white paper with tweezers or just push the screwdriver through the paper.
    Demander à FixBot
  5. OnePlus 8 Pro Battery Replacement: étape 5, image 1 de 2 OnePlus 8 Pro Battery Replacement: étape 5, image 2 de 2
    • Carefully lift the two stickers which hold the wireless charging coil down.
    Demander à FixBot
  6. OnePlus 8 Pro Battery Replacement: étape 6, image 1 de 1
    • Lift the charging coil.
    • Remove the two Phillips 00 screws below the coil.
    Demander à FixBot
  7. OnePlus 8 Pro Battery Replacement: étape 7, image 1 de 1
    • Remove the top cover / coil assembly.
    Demander à FixBot
  8. OnePlus 8 Pro Battery Replacement: étape 8, image 1 de 1
    • Disconnect the battery.
    Demander à FixBot
  9. OnePlus 8 Pro Battery Replacement: étape 9, image 1 de 1
    • Pull the red pulling tab away from the battery.
    • Separate the red pulling tab from the black adhesive.
    • After separating, hold the black adhesive down and pull the red tab up vertically to remove the battery.
    • Make sure not to bend the battery too heavily.
    Demander à FixBot
  10. OnePlus 8 Pro Battery Replacement: étape 10, image 1 de 2 OnePlus 8 Pro Battery Replacement: étape 10, image 2 de 2
    • Remove the red pulling tab from the old battery and stick it on the under side of the new battery.
    • This makes it easier to replace the battery again.
    • Insert the new battery.
    • Wrap the black adhesive strips on both sides around the battery to secure it.
    Demander à FixBot
  11. OnePlus 8 Pro Battery Replacement: étape 11, image 1 de 1
    • Remove the old adhesive and replace it with new adhesive strips.
    • Reverse from step 8 to assemble the phone.
    Demander à FixBot
Manuel Graf
Membre depuis le 01/21/20
220 Réputation
1 tutoriel rédigé
1 commentaire de tutoriel
be carefull: the adhesives of the back cover are not only on the edge, but also on the 4 corners (see the back cover on photo of step 4). You should carefully cut these off from the short edges, BEFORE trying to lift the cover.
LeFils - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 27
30 derniers jours : 172
Total : 2,742
