Aller au contenu principal
OnePlus Nord N20 5G Screen Replacement
Ce dont vous avez besoin
  1. OnePlus Nord N20 5G Screen Replacement, Back Cover: étape 1, image 1 de 1
    • Insert the SIM ejection tool or a spudger in the small hole next to the SIM tray.
    • Push it gently until the tray pops out.
    • Remove the SIM card tray by sliding it outwards.
  2. OnePlus Nord N20 5G Screen Replacement: étape 2, image 1 de 2 OnePlus Nord N20 5G Screen Replacement: étape 2, image 2 de 2
    • Heat the iOpener in a microwave for about 30 seconds. If the iOpener isn’t hot enough, reheat it for another 10-30 seconds.
    • Apply the heated iOpener on the backside of the phone for a minute to loosen the adhesive.
    • Use the iFixit opening tool and slide it along the edges of the phone to pry the back panel off.
  3. OnePlus Nord N20 5G Screen Replacement, Screen: étape 3, image 1 de 1
    • Remove the 18 3.9 mm screws using a Phillips #0 screwdriver.
  4. OnePlus Nord N20 5G Screen Replacement: étape 4, image 1 de 2 OnePlus Nord N20 5G Screen Replacement: étape 4, image 2 de 2
    • Take the iFixit opening tool and run it along the edges.
    • Separate the back housing from the frame of the screen.
  5. OnePlus Nord N20 5G Screen Replacement: étape 5, image 1 de 2 OnePlus Nord N20 5G Screen Replacement: étape 5, image 2 de 2
    • Disconnect the brackets attached to the motherboard using a spudger.
  6. OnePlus Nord N20 5G Screen Replacement: étape 6, image 1 de 1
    • Disconnect the bracket attached to the daughterboard using a spudger.
  7. OnePlus Nord N20 5G Screen Replacement: étape 7, image 1 de 1
    • Remove the battery.
    • This step is to ensure the heat from the iOpener does not damage the phone's battery.
  8. OnePlus Nord N20 5G Screen Replacement: étape 8, image 1 de 1
    • Heat up an iOpener for 30 seconds.
    • Place it on the front of the screen until you are able to slide a Jimmy in between the screen and the phone.
    • Make sure you do not overheat the screen or camera as it might damage the camera lens.
  9. OnePlus Nord N20 5G Screen Replacement: étape 9, image 1 de 1
    • Attach a suction handle to the screen.
    • Avoid being too rough to prevent more damage.
  10. OnePlus Nord N20 5G Screen Replacement: étape 10, image 1 de 2 OnePlus Nord N20 5G Screen Replacement: étape 10, image 2 de 2
    • Use a suction tool to pull the screen while prying the screen with a Jimmy.
    • The glue around the edges may need to be warmed up multiple times.
Mayson Solis
Membre depuis le 06/21/21
169 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 20
30 derniers jours : 73
Total : 221
