Introduction
As great as the OnePlus X is, it is not indestructible. If a heartbreaking (or glass-breaking) fall occurs, use this guide to remove the rear panel.
Ce dont vous avez besoin
Power off the phone by pressing the button on the right side of the phone, it will be the smaller button.
Press and hold the button down for a few seconds, until the option "Power Off" appears on the screen.
Select "Power Off" on the screen to turn off the phone.
Using a heat gun, apply slow and even heat to the edges of the back panel.
While heating the back panel, use a Jimmy to test if the adhesive is soft enough to allow the panel to separate from the device.
Carefully detach the back panel, using opening picks to hold the panel apart from the device.
Once most of the edges are separated from the device, attach a suction cup to the back panel.
8 autres ont terminé cette réparation.
4 commentaires de tutoriel
where can i buy the adhesive to stick it back or reuse the adhesive and reheat it up
How much cost to change one plus x back cover
How do you attach the new panel back?
well, this is not an “exchange”, but rather only a “removal” guide… please don’t mislead your readers and search results.
