Introduction
Problem: CD playing problems as cracking, fas-forwarding, lack of bass...
Problem can be solved by cleaning the laser lense.
Ce dont vous avez besoin
Remove the data cable from the amplifier by pulling during pressing the plug on both sides
Remove the 4 crews on the sides and the 3 screws on the back to remove the cover
Outil utilisé dans cette étape :Microfiber Cleaning Cloths$3.99
Take a microfiber cloth or any clean cloth which is lint-free
Wrap it around a flat screwdriver and soak it with high-percentage cleaning alcohol. I used 80% alcohol and it worked fine
Clean gently and carefully the lense
Turn the laser back to its standard position with the gearwheel
