Aller au contenu principal
OontZ Angle 3 Speaker Replacement
Ce dont vous avez besoin
  1. OontZ Angle 3 Speaker Replacement, Back Case: étape 1, image 1 de 3 OontZ Angle 3 Speaker Replacement, Back Case: étape 1, image 2 de 3 OontZ Angle 3 Speaker Replacement, Back Case: étape 1, image 3 de 3
    • Make sure that the OontZ Angle 3 is powered off before starting the disassembly.
    • Use the plastic opening tool to remove the rubber caps from each end of the speaker.
  2. OontZ Angle 3 Speaker Replacement: étape 2, image 1 de 1
    • Remove four (4) 11.7 mm Phillips #0 screws from each side at the bottom of the speaker.
  3. OontZ Angle 3 Speaker Replacement: étape 3, image 1 de 2 OontZ Angle 3 Speaker Replacement: étape 3, image 2 de 2
    • Use the plastic opening tool on one of the corners to separate the bottom piece from the speaker, and then remove the piece.
  4. OontZ Angle 3 Speaker Replacement, Speaker: étape 4, image 1 de 2 OontZ Angle 3 Speaker Replacement, Speaker: étape 4, image 2 de 2
    • Use the plastic opening tool to remove the front speaker plate from the speaker.
  5. OontZ Angle 3 Speaker Replacement: étape 5, image 1 de 2 OontZ Angle 3 Speaker Replacement: étape 5, image 2 de 2
    • Remove the eight (8) 5.25mm screws with the Phillips #0 screwdriver.
    • Open access to the speakers by letting them rest as shown.
  6. OontZ Angle 3 Speaker Replacement: étape 6, image 1 de 2 OontZ Angle 3 Speaker Replacement: étape 6, image 2 de 2
    • Use the soldering iron to carefully disconnect the speaker(s) from the motherboard connection wires.
    • Learn more about soldering here.
    • Remove the disconnected speaker(s).
    • When reconnecting the wires to the new speaker(s), be careful to connect the wires to the correct nodes (red for positive and black for negative). If they are reconnected to the wrong locations the speakers will either not work or break.
10 autres ont terminé cette réparation.
Mason Hollander
Membre depuis le 01/20/16
1 387 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 15-6, Remmell Spring 2016 Membre de l'équipe USF Tampa, Team 15-6, Remmell Spring 2016
USFT-REMMELL-S16S15G6
4 membres
4 tutoriels rédigés
7 commentaires
Where do you buy replacement speakers?
michalfiona - Réponse
Where do you buy the replacement speakers?
What type to buy?
where i buy the speaker replacement/
Sharina Uadan - Réponse
Where can i buy the replacement speakers
Anil Meda - Réponse
same question, I am looking for original speaker for oontz angle 3 and I can’t find one. Those who are looking for the size, its 40x40mm (1.57”) 4ohms 3W
Dwayne Champ Manuel - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 29
30 derniers jours : 94
Total : 8,114
