Aller au contenu principal
Opening DXG 567V HD Camera Case
Ce dont vous avez besoin
  1. Opening DXG 567V HD Camera Case, Opening DXG 567V HD Camera Case: étape 1, image 1 de 2 Opening DXG 567V HD Camera Case, Opening DXG 567V HD Camera Case: étape 1, image 2 de 2
    • This camcorder is a 720p HD camcorder that costs very little.
  2. Opening DXG 567V HD Camera Case: étape 2, image 1 de 2 Opening DXG 567V HD Camera Case: étape 2, image 2 de 2
    • The first step is to open the hatch for the batteries. to do this, on the right side there is a door that you push down on and it opens.
    • Now remove the two s screws highlighted in red.
  3. Opening DXG 567V HD Camera Case: étape 3, image 1 de 1
    • Now at the bottom of the device there is a screw circled in red that is hidden under a warranty sticker (in blue).
    • THIS STEP WILL VOID YOUR WARRANTY!
  4. Opening DXG 567V HD Camera Case: étape 4, image 1 de 1
    • On the top side there is a screw (circled) that is under a little black dot. Peel that dot off with a knife or pointed spudger.
  5. Opening DXG 567V HD Camera Case: étape 5, image 1 de 1
    • On the left side there is another screw under the black dot.
  6. Opening DXG 567V HD Camera Case: étape 6, image 1 de 1
    • On the right side (battery door hatch side), there is another screw under a black dot.
  7. Opening DXG 567V HD Camera Case: étape 7, image 1 de 1
    • Now carefully using a spudger or case opening tool, carefully rise the front bezel from the back casing by working around the device.
  8. Opening DXG 567V HD Camera Case: étape 8, image 1 de 1
    • When lifting the front off the hatch for the batteries will come off. when putting it back together put the spring (in green) in between the rail holders (in red) then slip it on the rail (yellow).
toddsifix
Membre depuis le 07/09/12
160 Réputation
1 tutoriel rédigé
Équipe
iFix Membre de l'équipe iFix
Community
2 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 1,186
