Introduction
To do anything inside of the HP 255 G7, you will need to remove the bottom cover of the laptop. This guide will help you do so, giving you access to the inside.
Ce dont vous avez besoin
Firstly, flip the laptop upside down, so that you are looking at the bottom of it, and the hinge of the screen is facing away from you.
Use the spatula to remove the rubber "leg", all the way until it is completely removed.
Unscrew all the screws from the laptop, including the ones that were under the rubber "legs".
Carefully insert a pick under the touchpad of the laptop.
2 autres ont terminé cette réparation.
