Aller au contenu principal
Optoma HD20 Fan Replacement
Ce dont vous avez besoin
  1. Optoma HD20 Fan Replacement, Disassembling Optoma HD20 Cover: étape 1, image 1 de 2 Optoma HD20 Fan Replacement, Disassembling Optoma HD20 Cover: étape 1, image 2 de 2
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
  2. Optoma HD20 Fan Replacement: étape 2, image 1 de 1
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
  3. Optoma HD20 Fan Replacement: étape 3, image 1 de 1
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
  4. Optoma HD20 Fan Replacement: étape 4, image 1 de 1
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
  5. Optoma HD20 Fan Replacement, Fan: étape 5, image 1 de 1
    • Peel off the tape that is holding the metal casing down.
  6. Optoma HD20 Fan Replacement: étape 6, image 1 de 2 Optoma HD20 Fan Replacement: étape 6, image 2 de 2
    • Use a Phillips #1 screwdriver to unscrew the nine 4.5mm screws.
    • Use a Phillips #0 screwdriver to unscrew the three 2.5 mm screws. This will allow you to remove the metal casing.
  7. Optoma HD20 Fan Replacement: étape 7, image 1 de 1
    • Remove the metal casing by lifting it up off of the circuit board.
  8. Optoma HD20 Fan Replacement: étape 8, image 1 de 1
    • Unplug the six wires stemming from the circuit board.
  9. Optoma HD20 Fan Replacement: étape 9, image 1 de 1
    • Use a Philips #1 screwdriver to remove the four 4.5 mm screws
  10. Optoma HD20 Fan Replacement: étape 10, image 1 de 1
    • Remove the three 4.5 mm screws using the Philips #1 screwdriver.
  11. Optoma HD20 Fan Replacement: étape 11, image 1 de 1
    • Remove the two 4.5 mm screws located on either side of the VGA/SCART port using a 5 mm nut driver. This will further release the plastic backing from the motherboard.
  12. Optoma HD20 Fan Replacement: étape 12, image 1 de 1
    • Slightly rotate the motherboard clockwise. This will prevent ports from getting caught on the plastic backing.
    • Lift the plastic backing to remove it.
  13. Optoma HD20 Fan Replacement: étape 13, image 1 de 1
    • Ensure all screws are removed
    • Lift up the motherboard and take out the metal container beneath it.
    • Do this very carefully as there is still one cable attached.
  14. Optoma HD20 Fan Replacement: étape 14, image 1 de 1
    • Unplug the white connector underneath the right side of the circuit board.
    • To remove, pinch both sides of the connector and pull it away from the circuit board.
  15. Optoma HD20 Fan Replacement: étape 15, image 1 de 2 Optoma HD20 Fan Replacement: étape 15, image 2 de 2
    • Use a Phillips #1 screwdriver to remove four 5 mm screws. This will release the fan.
  16. Optoma HD20 Fan Replacement: étape 16, image 1 de 2 Optoma HD20 Fan Replacement: étape 16, image 2 de 2
    • Pull the fan away from the metal housing unit.
    • Gently lift the fan up and out of the device. The fan is now removed.
6 autres ont terminé cette réparation.
Trever
Membre depuis le 01/22/15
1 264 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 21-23, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 membres
6 tutoriels rédigés
6 commentaires
Very nice set of instructions! Excellent images and identification of items to remove. Thank you!
Graveyard Workshop - Réponse
Do you know where to get this fan for replacement? Having trouble finding a parts list.
Sterling Grogg - Réponse
Small fan is GB1245PKVX-8, large fan is KDE1285PTV1
Gyrovague -
I am trying to determine if the fan works or not. Should the fan come on when there is no bulb in the projector? I removed the bulb when it burned up and I am not sure whether it was due to a failed fan or simply the bulb.
merrill277 - Réponse
Amazing! Thank you!!! Took a bit of effort to get the fan but in the end it worked like a charm!! Thank you for saving money!!!!
Mike Popov - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 15
30 derniers jours : 51
Total : 12,844
