Aller au contenu principal
Optoma HD20 Focal Lens Replacement
Ce dont vous avez besoin
  1. Optoma HD20 Focal Lens Replacement, Disassembling Optoma HD20 Cover: étape 1, image 1 de 2 Optoma HD20 Focal Lens Replacement, Disassembling Optoma HD20 Cover: étape 1, image 2 de 2
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
  2. Optoma HD20 Focal Lens Replacement: étape 2, image 1 de 1
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
  3. Optoma HD20 Focal Lens Replacement: étape 3, image 1 de 1
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
  4. Optoma HD20 Focal Lens Replacement: étape 4, image 1 de 1
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
  5. Optoma HD20 Focal Lens Replacement, Focal Lens: étape 5, image 1 de 1
    • Use a Phillips #1 screwdriver to unscrew the small black 2 mm screw on the side of the focal lens.
  6. Optoma HD20 Focal Lens Replacement: étape 6, image 1 de 1
    • Remove the focal lens by twisting it clockwise until it comes off.
Trever
Membre depuis le 01/22/15
1 264 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 21-23, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 14
30 derniers jours : 24
Total : 4,305
