Aller au contenu principal
Oral-B Vitality Power Button Replacement
Ce dont vous avez besoin
  1. Oral-B Vitality Power Button Replacement, Power Button: étape 1, image 1 de 3 Oral-B Vitality Power Button Replacement, Power Button: étape 1, image 2 de 3 Oral-B Vitality Power Button Replacement, Power Button: étape 1, image 3 de 3
    • Using the pliers, rotate the head base 90 degrees counterclockwise and remove core from the handle.
  2. Oral-B Vitality Power Button Replacement: étape 2, image 1 de 1
    • Locate the 4 terminals connecting the power button to the circuit board.
  3. Oral-B Vitality Power Button Replacement: étape 3, image 1 de 3 Oral-B Vitality Power Button Replacement: étape 3, image 2 de 3 Oral-B Vitality Power Button Replacement: étape 3, image 3 de 3
    • Desolder the 4 terminals and remove the old button.
    • Remove as much of the old solder as possible.
  4. Oral-B Vitality Power Button Replacement: étape 4, image 1 de 1
    • Attach the new button by soldering the 4 terminals with new solder.
8 autres ont terminé cette réparation.
Grady Bennett
Membre depuis le 11/07/17
500 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S2-G1, Harley Fall 2017 Membre de l'équipe IUPUI, Team S2-G1, Harley Fall 2017
IUPUI-HARLEY-F17S2G1
3 membres
8 tutoriels rédigés
4 commentaires
In my case no need to change the button, just redo the solder and this is it.
the vibration has damaged the solder.
Al kri - Réponse
If you try to unsolder the battery it has some protection and it won't work anymore
Gigi Kent - Réponse
Before unsoldering the button, you can understand if it is good or not just bypassing it with a wire: with a copper wire you can touch two pins of the button (one on the right side, on on the left side); if the toothbrush starts and stop on each touch of the wire, the problem is the button. I recognize the problem in this way.
Manolo Cerello - Réponse
True except if the switch is permanently “on”. I think that was my case. Replacing the switch fixed the issue.
Mumble Tim -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 53
30 derniers jours : 197
Total : 9,718
