Aller au contenu principal
Oral-B White Pro 1000 Motherboard Replacement
Ce dont vous avez besoin
  1. Oral-B White Pro 1000 Motherboard Replacement, Motherboard: étape 1, image 1 de 1
    • Remove the brush head by pulling the top away from the base.
  2. Oral-B White Pro 1000 Motherboard Replacement: étape 2, image 1 de 3 Oral-B White Pro 1000 Motherboard Replacement: étape 2, image 2 de 3 Oral-B White Pro 1000 Motherboard Replacement: étape 2, image 3 de 3
    • Pry open the end cap from the toothbrush body.
    • Remove the spring.
  3. Oral-B White Pro 1000 Motherboard Replacement: étape 3, image 1 de 2 Oral-B White Pro 1000 Motherboard Replacement: étape 3, image 2 de 2
    • Apply pressure on the brush shaft to release the toothbrush internals.
    • Remove the internals through the bottom of the toothbrush body.
  4. Oral-B White Pro 1000 Motherboard Replacement: étape 4, image 1 de 2 Oral-B White Pro 1000 Motherboard Replacement: étape 4, image 2 de 2
    • Use flat head screwdriver to remove power button pressure plate.
  5. Oral-B White Pro 1000 Motherboard Replacement: étape 5, image 1 de 3 Oral-B White Pro 1000 Motherboard Replacement: étape 5, image 2 de 3 Oral-B White Pro 1000 Motherboard Replacement: étape 5, image 3 de 3
    • Desolder the coil wire from the motherboard.
    • Check out this helpful guide for some soldering and desoldering tips.
    • Squeeze and remove coil from motherboard.
  6. Oral-B White Pro 1000 Motherboard Replacement: étape 6, image 1 de 2 Oral-B White Pro 1000 Motherboard Replacement: étape 6, image 2 de 2
    • Desolder the motor from motherboard.
    • Remove motherboard and battery from body of toothbrush internals.
  7. Oral-B White Pro 1000 Motherboard Replacement: étape 7, image 1 de 2 Oral-B White Pro 1000 Motherboard Replacement: étape 7, image 2 de 2
    • Desolder the battery connections from the motherboard.
    • Remove motherboard from battery holder.
Reattach new motherboard and reassemble your device following instructions in reverse order. Solder appropriate connections during reassembly.
2 autres ont terminé cette réparation.
Hannah Parker
Membre depuis le 11/08/17
203 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S5-G4, Baechle Fall 2017 Membre de l'équipe IUPUI, Team S5-G4, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G4
3 membres
6 tutoriels rédigés
Un commentaire
Motor are brushless?
joseferreira_ms - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 72
Total : 2,609
