Aller au contenu principal
Ordro HDV-D395 Back Case Replacement
Ce dont vous avez besoin
  1. Ordro HDV-D395 Back Case Replacement, Back Case: étape 1, image 1 de 2 Ordro HDV-D395 Back Case Replacement, Back Case: étape 1, image 2 de 2
    • Pull the slider labeled open, on the bottom right, to unlock the battery.
  2. Ordro HDV-D395 Back Case Replacement: étape 2, image 1 de 1
    • Pull battery out of slot.
  3. Ordro HDV-D395 Back Case Replacement: étape 3, image 1 de 1
    • Unfold the screen from the side of the camera.
  4. Ordro HDV-D395 Back Case Replacement: étape 4, image 1 de 1
    • Twist the screen so that the screen is facing downward.
  5. Ordro HDV-D395 Back Case Replacement: étape 5, image 1 de 2 Ordro HDV-D395 Back Case Replacement: étape 5, image 2 de 2
    • Unscrew the four screws on the side (length 2.9 mm) with a JIS #000 screwdriver.
    • Unscrew the three screws on the bottom (length 7.7 mm) with a JIS #000 screwdriver.
  6. Ordro HDV-D395 Back Case Replacement: étape 6, image 1 de 1
    • Pull apart the camera into two pieces by pulling the side with the screen away from the main body of the camera.
  7. Ordro HDV-D395 Back Case Replacement: étape 7, image 1 de 2 Ordro HDV-D395 Back Case Replacement: étape 7, image 2 de 2
    • Unscrew the two screws (size 4.75 mm) with a PH #00 screwdriver.
    • Unscrew the screw (size 7.65 mm) with a PH #00 screwdriver.
  8. Ordro HDV-D395 Back Case Replacement: étape 8, image 1 de 1
    • Take the back case off by pulling it away from the main body.
    • Be careful not to tear the white strap that connects the back case to the main body.
  9. Ordro HDV-D395 Back Case Replacement: étape 9, image 1 de 1
    • Unscrew all four screws (length 4.13 mm) on the inside of the case with a PH #00 screwdriver.
  10. Ordro HDV-D395 Back Case Replacement: étape 10, image 1 de 1
    • Pull the board away from the back case.
Mostafa Abdulaleem
Membre depuis le 11/05/18
181 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S1-G3, Baechle Fall 2018 Membre de l'équipe IUPUI, Team S1-G3, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G3
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 7
Total : 295
