Aller au contenu principal
Oreva FX-82MS Battery Replacement
Ce dont vous avez besoin
  1. Oreva FX-82MS Battery Replacement, Battery: étape 1, image 1 de 1
    • Turn off the calculator by pressing the [Shift] button and then press the [AC][OFF] button, (while keeping the [Shift] button pressed down).
  2. Oreva FX-82MS Battery Replacement: étape 2, image 1 de 2 Oreva FX-82MS Battery Replacement: étape 2, image 2 de 2
    • Flip the calculator over so that the back panel faces up.
    • Use a Phillips #0 screwdriver to remove six, 1.2 mm screws starting from the upper right corner.
  3. Oreva FX-82MS Battery Replacement: étape 3, image 1 de 2 Oreva FX-82MS Battery Replacement: étape 3, image 2 de 2
    • Remove the back cover and put it to the side.
  4. Oreva FX-82MS Battery Replacement: étape 4, image 1 de 2 Oreva FX-82MS Battery Replacement: étape 4, image 2 de 2
    • Remove the two old batteries from the slots.
    • Be gentle when removing the batteries to avoid damaging the connectors.
  5. Oreva FX-82MS Battery Replacement: étape 5, image 1 de 3 Oreva FX-82MS Battery Replacement: étape 5, image 2 de 3 Oreva FX-82MS Battery Replacement: étape 5, image 3 de 3
    • Place the two new AAA batteries into the calculator, one by one.
    • Be sure that the direction of the + and - signs on your battery match the signs at the bottom of the battery compartment.
    • Place the case on back of the calculator.
  6. Oreva FX-82MS Battery Replacement: étape 6, image 1 de 2 Oreva FX-82MS Battery Replacement: étape 6, image 2 de 2
    • Use a Phillips #0 screwdriver to replace the 1.2 mm screws on the back case.
  7. Oreva FX-82MS Battery Replacement: étape 7, image 1 de 1
    • Reset the calculator by pressing [ON].
    • Press the [shift] button.
    • Press the [9] [CLR] button to clear the data.
    • Press the [3][ALL] button option.
    • Press [=] [yes] button to agree.
    • Press [AC] key to reset.
2 autres ont terminé cette réparation.
Prarthit patel
Membre depuis le 07/02/22
196 Réputation
1 tutoriel rédigé
Équipe
York University, Team M-22, Allen Summer 2022 Membre de l'équipe York University, Team M-22, Allen Summer 2022
YORK-ALLEN-SU22SMG22
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 13
30 derniers jours : 75
Total : 2,160
