Aller au contenu principal
Osmo Mobile Trigger Button Replacement
Ce dont vous avez besoin
  1. Osmo Mobile Trigger Button Replacement, Osmo Mobile Handle Disassembly: étape 1, image 1 de 2 Osmo Mobile Trigger Button Replacement, Osmo Mobile Handle Disassembly: étape 1, image 2 de 2
    • Remove gimbal from base handle by loosening round plate found at the top of the handle.
  2. Osmo Mobile Trigger Button Replacement: étape 2, image 1 de 2 Osmo Mobile Trigger Button Replacement: étape 2, image 2 de 2
    • Use Phillips #00 screwdriver to remove the three screws found on the gimbal stabilizer to detach handle from gimbal.
    • Carefully detach handle from gimbal and disconnect the cable that connects the two.
  3. Osmo Mobile Trigger Button Replacement: étape 3, image 1 de 1
    • Locate the hex screws found at the top base of the handle, and unscrew using the 1.5mm hex screwdriver.
  4. Osmo Mobile Trigger Button Replacement: étape 4, image 1 de 2 Osmo Mobile Trigger Button Replacement: étape 4, image 2 de 2
    • Remove joystick by gently pulling away from handle
  5. Osmo Mobile Trigger Button Replacement: étape 5, image 1 de 3 Osmo Mobile Trigger Button Replacement: étape 5, image 2 de 3 Osmo Mobile Trigger Button Replacement: étape 5, image 3 de 3
    • Remove the quick release PCBA by locating the connecting wires and release the ribbon cable with tweezers.
    • Use the spudger to pry open and remove the face plate, starting at the back of the handle.
  6. Osmo Mobile Trigger Button Replacement: étape 6, image 1 de 3 Osmo Mobile Trigger Button Replacement: étape 6, image 2 de 3 Osmo Mobile Trigger Button Replacement: étape 6, image 3 de 3
    • Locate four screws directly on top of handle.
    • Unscrew the silver, bottom two screws, that are closest to the face plate using the 00 screwdriver.
    • Unscrew the black, top two screws, located furthest from the face plate, using the 0 screwdriver.
    • Remove the remaining two screws found on the front of the faceplate.
    • Remove the rest of the face plate shell.
  7. Osmo Mobile Trigger Button Replacement, Charging Port: étape 7, image 1 de 1
    • Remove the top left screw on the joystick panel with Phillips #00 screwdriver.
    • Lift faceplate holding joystick module.
  8. Osmo Mobile Trigger Button Replacement: étape 8, image 1 de 1
    • Remove the bottom right screw on the joystick panel with the #00 Phillips screwdriver.
  9. Osmo Mobile Trigger Button Replacement: étape 9, image 1 de 1
    • Hold down the larger of the two ribbon cables, and pull on circuit board with a constant and careful down and out motion.
  10. Osmo Mobile Trigger Button Replacement: étape 10, image 1 de 1
    • Remove the two screws from the green charging module and the two screws on the grey plate and remove from handle.
    • Replace charging module.
  11. Osmo Mobile Trigger Button Replacement, Trigger Button: étape 11, image 1 de 2 Osmo Mobile Trigger Button Replacement, Trigger Button: étape 11, image 2 de 2
    • Use the tweezers to push outward on the backside of the trigger button hinges.
    • Pop out trigger button.
  12. Osmo Mobile Trigger Button Replacement: étape 12, image 1 de 1
    • Use the tweezers to remove the underlying button that contacts with the trigger button, and replace.
William Tyler Wills
Membre depuis le 09/28/17
426 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S2-G1, Nance Fall 2017 Membre de l'équipe USF Tampa, Team S2-G1, Nance Fall 2017
USFT-NANCE-F17S2G1
4 membres
12 tutoriels rédigés
Un commentaire
How I can fix the USB port, it went inside the handle?
Juan Carlos Beltran - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 24
Total : 2,456
