Aller au contenu principal
Oster 16-Speed Blender Container Replacement
Ce dont vous avez besoin
  1. Oster 16-Speed Blender Container Replacement, Container: étape 1, image 1 de 2 Oster 16-Speed Blender Container Replacement, Container: étape 1, image 2 de 2
    • First, remove the blender container from the Blender Base, by grabbing the handle and lifting up.
  2. Oster 16-Speed Blender Container Replacement: étape 2, image 1 de 2 Oster 16-Speed Blender Container Replacement: étape 2, image 2 de 2
    • Next, remove the lid from the Blender Container.
  3. Oster 16-Speed Blender Container Replacement: étape 3, image 1 de 2 Oster 16-Speed Blender Container Replacement: étape 3, image 2 de 2
    • Flip the container on its side so that the bottom faces you.
    • Now rotate the bottom counter-clockwise to remove it from the container.
  4. Oster 16-Speed Blender Container Replacement: étape 4, image 1 de 2 Oster 16-Speed Blender Container Replacement: étape 4, image 2 de 2
    • Now you will see the bottom of the blender blades once the bottom piece is removed
    • Carefully remove the blender blades from the container seeing as they are very sharp and can cut you.
  5. Oster 16-Speed Blender Container Replacement: étape 5, image 1 de 1
    • Now your container is separated.
With your container separated, it can now be replaced. To reassemble your device, follow these instructions in reverse order.
Dana
Membre depuis le 04/14/14
779 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 12-37, Maness Spring 2014 Membre de l'équipe Cal Poly, Team 12-37, Maness Spring 2014
CPSU-MANESS-S14S12G37
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 1,042
