Aller au contenu principal
Oster 3905 Outer Shell Replacement
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
Ce dont vous avez besoin
  1. Oster 3905 Outer Shell Replacement, Slot Levers: étape 1, image 1 de 1
    • Firmly grip your hand around the slot lever.
  2. Oster 3905 Outer Shell Replacement: étape 2, image 1 de 1
    • Stabilize the toaster by placing your hand on top.
  3. Oster 3905 Outer Shell Replacement: étape 3, image 1 de 2 Oster 3905 Outer Shell Replacement: étape 3, image 2 de 2
    • Forcefully pull the slot lever away from the toaster by keeping parallel to the table.
  4. Oster 3905 Outer Shell Replacement: étape 4, image 1 de 1
    • Both slot levers can be removed.
  5. Oster 3905 Outer Shell Replacement, Outer Shell: étape 5, image 1 de 1
    • Place the toaster upside down so the bottom is facing the ceiling.
  6. Oster 3905 Outer Shell Replacement: étape 6, image 1 de 2 Oster 3905 Outer Shell Replacement: étape 6, image 2 de 2
    • Take off both rubber feet using a small metal spudger.
    • Wedge a spudger under the feet and pull up to pop off.
  7. Oster 3905 Outer Shell Replacement: étape 7, image 1 de 1
    • Use a PH#2 screw bit to remove eight 12mm screws that are located around the perimeter.
    • There are two screws under the rubber feet.
  8. Oster 3905 Outer Shell Replacement: étape 8, image 1 de 1
    • Place the toaster right side up.
  9. Oster 3905 Outer Shell Replacement: étape 9, image 1 de 2 Oster 3905 Outer Shell Replacement: étape 9, image 2 de 2
    • Grab the outer shell firmly and pull up towards the face of the toaster.
  10. Oster 3905 Outer Shell Replacement: étape 10, image 1 de 1
    • For this part, you might need to wiggle the toaster to get the outer shell off.
    • The shell will not completely come off until the motherboard is removed in the next step.
  11. Oster 3905 Outer Shell Replacement: étape 11, image 1 de 3 Oster 3905 Outer Shell Replacement: étape 11, image 2 de 3 Oster 3905 Outer Shell Replacement: étape 11, image 3 de 3
    • Use a J1 screw bit to unscrew eight 8mm screws from the motherboard.
  12. Oster 3905 Outer Shell Replacement: étape 12, image 1 de 2 Oster 3905 Outer Shell Replacement: étape 12, image 2 de 2
    • Take out the grey “cancel” and “bagel” buttons from the shell.
Melissa
Membre depuis le 09/12/16
198 Réputation
1 tutoriel rédigé
Équipe
CSU Fullerton, Team 2-1, Bruce Fall 2016 Membre de l'équipe CSU Fullerton, Team 2-1, Bruce Fall 2016
CSUF-BRUCE-F16S2G1
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 7
Total : 129
