Aller au contenu principal
Oster 6329 Circuit Board Resistor Replacement
Ce dont vous avez besoin
  1. Oster 6329 Circuit Board Resistor Replacement, Outer Shell Removal: étape 1, image 1 de 2 Oster 6329 Circuit Board Resistor Replacement, Outer Shell Removal: étape 1, image 2 de 2
    • Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
  2. Oster 6329 Circuit Board Resistor Replacement: étape 2, image 1 de 1
    • Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
  3. Oster 6329 Circuit Board Resistor Replacement: étape 3, image 1 de 1
    • Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
    • Only lift the outer shell a little so as not to disconnect the cables that connect the circuit board.
  4. Oster 6329 Circuit Board Resistor Replacement: étape 4, image 1 de 2 Oster 6329 Circuit Board Resistor Replacement: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
  5. Oster 6329 Circuit Board Resistor Replacement: étape 5, image 1 de 2 Oster 6329 Circuit Board Resistor Replacement: étape 5, image 2 de 2
    • Lift the top outer metal shell.
    • Carefully lift the outer metal shell at an angle so as not to damage the components in the front of the toaster.
  6. Oster 6329 Circuit Board Resistor Replacement, Circuit Board Resistor: étape 6, image 1 de 1
    • Using a #1 phillips head screwdriver, remove the four 1cm philips head screws holding the circuit board to the inside of the toaster shell.
  7. Oster 6329 Circuit Board Resistor Replacement: étape 7, image 1 de 1
    • Grasp the circuit board and pull on it perpendicular to the attached surface.
  8. Oster 6329 Circuit Board Resistor Replacement: étape 8, image 1 de 1
    • Inspect the circuit board for any burnt or otherwise damaged components. Be sure to carefully identify the damaged components that need replacement. For help identifying resistor values look at wikipedia's electronic color code article.
  9. Oster 6329 Circuit Board Resistor Replacement: étape 9, image 1 de 1
    • Use the soldering kit to unsolder the damaged component. For soldering Instructions look at the iFixit Soldering Guide.
  10. Oster 6329 Circuit Board Resistor Replacement: étape 10, image 1 de 1
    • Once the damaged component has been unsoldered from the circuit board, remove it.
Timothy Grijalva
Membre depuis le 01/31/14
234 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 13-15, Regan Winter 2014 Membre de l'équipe Cal Poly, Team 13-15, Regan Winter 2014
CPSU-REGAN-W14S13G15
5 membres
6 tutoriels rédigés
Un commentaire
Where are replacement parts for a toaster available typically?
Bruce odom - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 12
Total : 2,146
