Introduction
Removing the power cord is straightforward, but it does require soldering.
Ce dont vous avez besoin
Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
Using a flat-head screwdriver, pry the power cord from the base of the toaster.
Presque terminé !
