Aller au contenu principal
Oster BVST-EK5967 Electric Kettle Disassembly
Ce dont vous avez besoin
  1. Oster BVST-EK5967 Electric Kettle Disassembly, Temperature Reader and Heating Element: étape 1, image 1 de 2 Oster BVST-EK5967 Electric Kettle Disassembly, Temperature Reader and Heating Element: étape 1, image 2 de 2
    • Make sure the device is unplugged and free of any liquid.
    • Remove the plastic base at the bottom of the kettle.
  2. Oster BVST-EK5967 Electric Kettle Disassembly: étape 2, image 1 de 2 Oster BVST-EK5967 Electric Kettle Disassembly: étape 2, image 2 de 2
    • Remove the four 3 mm screws at the base of the kettle by using the screwdriver.
  3. Oster BVST-EK5967 Electric Kettle Disassembly: étape 3, image 1 de 2 Oster BVST-EK5967 Electric Kettle Disassembly: étape 3, image 2 de 2
    • Remove the three 3 mm screws near the circular part of the kettle.
  4. Oster BVST-EK5967 Electric Kettle Disassembly: étape 4, image 1 de 2 Oster BVST-EK5967 Electric Kettle Disassembly: étape 4, image 2 de 2
    • Remove the three 10 mm screws.
  5. Oster BVST-EK5967 Electric Kettle Disassembly: étape 5, image 1 de 2 Oster BVST-EK5967 Electric Kettle Disassembly: étape 5, image 2 de 2
    • Use a spudger to remove the lid from the top of the kettle.
    • Remove the two 12 mm screws near the temperature reader.
  6. Oster BVST-EK5967 Electric Kettle Disassembly: étape 6, image 1 de 2 Oster BVST-EK5967 Electric Kettle Disassembly: étape 6, image 2 de 2
    • Remove the two 10 mm screws from the inner layer of the handle.
  7. Oster BVST-EK5967 Electric Kettle Disassembly: étape 7, image 1 de 2 Oster BVST-EK5967 Electric Kettle Disassembly: étape 7, image 2 de 2
    • Remove the outer layer from the handle using a spudger.
    • Remove the bottom 3 mm screw.
  8. Oster BVST-EK5967 Electric Kettle Disassembly: étape 8, image 1 de 2 Oster BVST-EK5967 Electric Kettle Disassembly: étape 8, image 2 de 2
    • Separate the parts of the kettle to see its wiring.
Here is some general information about the kettle's use and electric components:
The kettle is always connected to a power source when plugged in, but the electrical circuit remains open until the user activates it by pressing the power button. Once pressed, the circuit is closed, allowing electricity to flow through the system and start heating the water.
Inside the base, a heating element converts electrical energy into heat. This element is in direct contact with the bottom of the kettle, where it heats the water. The temperature is monitored by a built-in thermostat. When the water reaches the pre-set temperature, the thermostat detects this change and automatically cuts off power to the heating element, stopping the heating process.
The kettle also has a boil-dry protection mechanism. If the kettle is turned on without sufficient water inside, the heating element heats up too quickly. The thermostat recognizes this abnormal temperature rise and immediately cuts off the power to prevent damage or hazards.
Riley Becker
Membre depuis le 09/10/24
207 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 51
Total : 139
