Aller au contenu principal
Oster Blend-N-Go My Blend Blade Assembly Replacement
  1. Oster Blend-N-Go My Blend Blade Assembly Replacement, Blender Bottle: étape 1, image 1 de 2 Oster Blend-N-Go My Blend Blade Assembly Replacement, Blender Bottle: étape 1, image 2 de 2
    • Grip the blender base with one hand and blender bottle with the other hand.
    • Rotate the blender bottle a quarter turn counterclockwise .
    • Lift the blender bottle out of the blender base. The blade assembly should still be attached to the blender bottle.
  2. Oster Blend-N-Go My Blend Blade Assembly Replacement: étape 2, image 1 de 3 Oster Blend-N-Go My Blend Blade Assembly Replacement: étape 2, image 2 de 3 Oster Blend-N-Go My Blend Blade Assembly Replacement: étape 2, image 3 de 3
    • Grip the blade assembly with one hand and blender bottle with the other hand.
    • Rotate the blade assembly counterclockwise until it is completely unscrewed from the blender bottle.
    • Lift the blender bottle to separate it from the blade assembly.
  3. Oster Blend-N-Go My Blend Blade Assembly Replacement, Blade Assembly: étape 3, image 1 de 1
    • After removing the blade assembly from the blender bottle, ensure your blade assembly has its seal placed in the seal bed.
Paul Long
Membre depuis le 08/27/15
710 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 12-6, Blackwell Fall 2015 Membre de l'équipe USF Tampa, Team 12-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G6
3 membres
5 tutoriels rédigés
2 commentaires
I’m confused, these are the steps you have to go through every single time you use this blender to blend something. This isn’t really a “replacement” process here. If someone needs to repair a cracked blade assembly or buy a new one, how would they do that?
Alan M - Réponse
This process is not helpful at all. I followed as instructed but the blade is not moving at all?! What is going on? Pls provide better HELP INSTRUCTIONS.
Fareda Edwards - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 24
Total : 3,627
