Aller au contenu principal
Oster Designer Egg Cooker and Poacher Disassembly
Ce dont vous avez besoin
Document vedette
  1. Oster Designer Egg Cooker and Poacher Disassembly, Oster Designer Egg Cooker and Poacher Disassembly: étape 1, image 1 de 1
    • Remove the plastic covering from your Oster egg cooker, and turn your egg-poacher upside down.
    • Remove the single screw in the center of the bottom surface of your egg cooker.
    • Separate the plastic covering from the metal base.
  2. Oster Designer Egg Cooker and Poacher Disassembly: étape 2, image 1 de 2 Oster Designer Egg Cooker and Poacher Disassembly: étape 2, image 2 de 2
    • Remove the single screw using a Phillips screwdriver.
    • This will free the clear plastic cube that encases a small light bulb.
    • This acts as a light indicator for when the machine is turned on and provides a reddish glow upon pressing the "push to start" button.
  3. Oster Designer Egg Cooker and Poacher Disassembly: étape 3, image 1 de 3 Oster Designer Egg Cooker and Poacher Disassembly: étape 3, image 2 de 3 Oster Designer Egg Cooker and Poacher Disassembly: étape 3, image 3 de 3
    • Now that you have loosened the clear plastic cube, you'll now move on to the bimetallic strip.
    • This metal strip runs between the switch mechanism.
    • You'll see a screw, fastened with a nut and washer. To remove the strip, unscrew it, and set aside the now free metal piece, screw, nut, and washer.
  4. Oster Designer Egg Cooker and Poacher Disassembly: étape 4, image 1 de 1
    • At this point, you have successfully disassembled your Oster Egg Cooker and Poacher. You can now examine the circuit that runs the machine. Pictured here is the circular heating element, which has a resistance of 28.7 ohms.
  5. Oster Designer Egg Cooker and Poacher Disassembly: étape 5, image 1 de 2 Oster Designer Egg Cooker and Poacher Disassembly: étape 5, image 2 de 2
    • Let's take a closer look at the switch mechanism: In the 1st photo, you'll see that the switch is in the off position, as the black wedge is not in place within the appropiate notch etched into the golden piece.
    • In the 2nd photo, you can see the black wedge has been pushed into place within the golden piece. This is regularly accomplished after having pushed the red "push to start" button found on the metal frame where the egg cooker's label can be found. This process turns the machine on and initiates the cooking process.
    • Notice the bimetallic piece from Step 2 letting the gold piece hold the black wedge in the on position.
    • When the device heats up enough to cook the eggs, this bimetallic strip will bend in the direction of the green arrow, pushing the switch back into the off position, and turning the machine off.
  6. Oster Designer Egg Cooker and Poacher Disassembly: étape 6, image 1 de 1
    • Congratulations! You have successfully disassembled your Oster Designer Egg Cooker and Poacher! Happy egg cooking!
Pièces jointes
Un commentaire
how easy is to find replacement parts for this item
cookingathome - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 25
Total : 624
