Aller au contenu principal
Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement
Ce dont vous avez besoin
  1. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Thermal Cutoff Fuse: étape 1, image 1 de 2 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Thermal Cutoff Fuse: étape 1, image 2 de 2
    • This is an Oster Digital Electric Kettle
  2. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Remove the bottom: étape 2, image 1 de 3 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Remove the bottom: étape 2, image 2 de 3 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Remove the bottom: étape 2, image 3 de 3
    • Remove the three screws. They are tri-wing or triangular slotted screws. My set labeled them as number 4.
    • Once removed the plastic cover comes right off.
  3. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Find the Thermal Cutoff Fuse: étape 3, image 1 de 3 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Find the Thermal Cutoff Fuse: étape 3, image 2 de 3 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Find the Thermal Cutoff Fuse: étape 3, image 3 de 3
    • The Thermal Cutoff Fuse is pressed up against the heat element by a spring clip.
    • Remove the screw, a standard number 2 phillips head.
    • Slide the fiberglass sleeve down and off the fuse
  4. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Test the fuse: étape 4, image 1 de 2 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Test the fuse: étape 4, image 2 de 2
    • With ohm meter connected either way the fuse is open. A sure sign that the part is bad.
  5. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Verify the new fuse: étape 5, image 1 de 2 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Verify the new fuse: étape 5, image 2 de 2
    • Testing the new fuse shows that electricity can flow through it.
    • I purchased 5x of SF188E 192 10A/250V SEFUSE on ebay. You can just search for whatever is written on the side of yours.
  6. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Replace the fuse: étape 6, image 1 de 2 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Replace the fuse: étape 6, image 2 de 2
    • Replace the fuse. The black band is down in this picture.
    • The difficult part is that this part is not soldered in, it is held together with a crimp band.
    • So one must slowly open the band and then crimp it back on the new fuse.
    • I really have no good way of doing this, and it is the most time consuming and frustrating part of the whole repair. Take your time with a pick and pliers and slowly open them and replace the fuse.
  7. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Put all back together: étape 7, image 1 de 2 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Put all back together: étape 7, image 2 de 2
    • Now just slide the fiberglass sleeve back over the fuse.
    • Reattach the spring clip to hold the fuse on the heat element.
    • Make sure that the clip is directly over the fuse before tightening.
    • Replace the plastic cover and install the three tri-wing screws.
  8. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Try it out: étape 8, image 1 de 1
    • Plug it back in and see if it heats water.
22 autres ont terminé cette réparation.
Scot Henderson
Membre depuis le 05/18/15
857 Réputation
2 tutoriels rédigés
8 commentaires
Мне нравится этот чайник мне его подарили но проблема у нас электричество на 220 вольт. Вопрос как эго переделать на 220.
digital electronic kettle
Model: BVST-EK5967
120Vac 60HZ
vikangel - Réponse
я не думаю, что это будет иметь значение для предохранителя. плавкий предохранитель рассчитан на 250 в, так что это может быть тот же предохранитель в 220 чайника.
я хотел бы посмотреть на предохранитель и посмотреть, если вы можете прочитать его. тогда просто заменить с тем же.
Scot Henderson - Réponse
Where is fuse in Oster electric kettle BVSTKT5970
munu88 - Réponse
this helped me 100 percent
joshua hofer - Réponse
These steps worked fine for me. They are clear and concise. On Step 6, rather than trying to pry the crimp bands off, I cut them off and used new bands that came with the new fuse - much quicker.
Philip McCue - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 12
7 derniers jours : 29
30 derniers jours : 57
Total : 18,645
