Aller au contenu principal
Oster Expressbake CKSTBRTW20 Inner Chamber Replacement
Ce dont vous avez besoin
  1. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement, Top Panel Removal: étape 1, image 1 de 1
    • Remove the bread pan.
  2. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: étape 2, image 1 de 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: étape 2, image 2 de 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: étape 2, image 3 de 3
    • Remove the eight 22mm Phillips #1 screws from the grey lining.
    • Remove the grey liner.
  3. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: étape 3, image 1 de 2 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: étape 3, image 2 de 2
    • Remove the two 11mm Phillips #1 screws from the back of the device.
  4. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: étape 4, image 1 de 2 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: étape 4, image 2 de 2
    • Pop off the top case using a spudger.
    • Keep the spudger away from the control panel.
    • Be aware of wires connecting the microcontroller to the panel when removing the top lining.
  5. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement, Inner Chamber: étape 5, image 1 de 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement, Inner Chamber: étape 5, image 2 de 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement, Inner Chamber: étape 5, image 3 de 3
    • Disconnect microcontroller and top lining.
    • Ground yourself prior to disconnecting in order to avoid harming the inner electronics.
  6. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: étape 6, image 1 de 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: étape 6, image 2 de 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: étape 6, image 3 de 3
    • Remove the four 11mm Phillips #1 screws holding from the guard and inner lining.
    • Remove small rectangular guard from bottom of liner
  7. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: étape 7, image 1 de 1
    • Remove the inner liner.
    • The inner liner will be connected to the outer chamber with wires.
  8. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: étape 8, image 1 de 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: étape 8, image 2 de 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: étape 8, image 3 de 3
    • Disconnect the red wires from the inner liner.
  9. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: étape 9, image 1 de 2 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: étape 9, image 2 de 2
    • Remove the single 11mm Phillips #1 screw thats holding and inner lining in place.
  10. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: étape 10, image 1 de 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: étape 10, image 2 de 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: étape 10, image 3 de 3
    • Use a spudger to push out the connector found on the inner lining.
  11. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: étape 11, image 1 de 2 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: étape 11, image 2 de 2
    • Remove lining.
Megan Saunders
Membre depuis le 01/25/18
701 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S7-G5, Passmore Spring 2018 Membre de l'équipe USF Tampa, Team S7-G5, Passmore Spring 2018
USFT-PASSMORE-S18S7G5
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 470
