Introduction
This guide explains how to expose each of the two buttons of the Ozeri Pronto ZK14-S in the same steps. Each button is attached to a different motherboard. A soldering iron will be necessary to remove the buttons from the motherboard. Please view the following link for detailed instructions on how to operate a soldering iron: How To Solder and Desolder Connections
Ce dont vous avez besoin
Outil utilisé dans cette étape :Flathead 3/32" or 2.5 mm Screwdriver$5.49
Using a 2.0 Flathead screwdriver, remove the two 7.34 mm screws on the smaller motherboards.
