Aller au contenu principal
Ozeri Pronto ZK14-S LCD Replacement
Ce dont vous avez besoin
  1. Ozeri Pronto ZK14-S LCD Replacement, Panel Removal: étape 1, image 1 de 2 Ozeri Pronto ZK14-S LCD Replacement, Panel Removal: étape 1, image 2 de 2
    • Twist the plastic plate slowly to the left to pull it away.
  2. Ozeri Pronto ZK14-S LCD Replacement: étape 2, image 1 de 1
    • Pry off the sticker at the bottom where the “Ozeri” logo is to reveal a screw. The sticker does not need to be completely removed for the next step.
  3. Ozeri Pronto ZK14-S LCD Replacement: étape 3, image 1 de 1
    • Using the 2.0 Flathead screwdriver, remove the 9.50 mm Phillips head screw under the sticker.
  4. Ozeri Pronto ZK14-S LCD Replacement: étape 4, image 1 de 2 Ozeri Pronto ZK14-S LCD Replacement: étape 4, image 2 de 2
    • Using the 2.0 Flathead screwdriver, remove the two 18.76 mm Phillips head screws in the plate stand.
  5. Ozeri Pronto ZK14-S LCD Replacement: étape 5, image 1 de 2 Ozeri Pronto ZK14-S LCD Replacement: étape 5, image 2 de 2
    • Using the 2.0 Flathead screwdriver, remove the 9.44 mm Phillips head screw on the end opposite of the LCD screen.
  6. Ozeri Pronto ZK14-S LCD Replacement: étape 6, image 1 de 1
    • Turn the device over so the back panel is facing up.
  7. Ozeri Pronto ZK14-S LCD Replacement: étape 7, image 1 de 1
    • Using the plastic opening tool, pry off each of the two rubber stubs on the right side and the two stubs on the left side of bottom of the device.
  8. Ozeri Pronto ZK14-S LCD Replacement: étape 8, image 1 de 1
    • Using the 2.0 Flathead screwdriver, remove of the four 9.46 mm Phillips head screws under the removed stubs.
  9. Ozeri Pronto ZK14-S LCD Replacement: étape 9, image 1 de 2 Ozeri Pronto ZK14-S LCD Replacement: étape 9, image 2 de 2
    • Pry apart the two panels to separate them from each other.
    • Flip the device over so the LCD is facing up. Flip the front panel over on its side.
    • Be careful when separating the panels to avoid damaging the wires they are connected by.
  10. Ozeri Pronto ZK14-S LCD Replacement, LCD: étape 10, image 1 de 2 Ozeri Pronto ZK14-S LCD Replacement, LCD: étape 10, image 2 de 2
    Outil utilisé dans cette étape :
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    J'achète
    • Using the 2.0 Flathead screwdriver, remove the three 7.20 mm screw on the back of the center LCD motherboard.
  11. Ozeri Pronto ZK14-S LCD Replacement: étape 11, image 1 de 3 Ozeri Pronto ZK14-S LCD Replacement: étape 11, image 2 de 3 Ozeri Pronto ZK14-S LCD Replacement: étape 11, image 3 de 3
    • Stand the center motherboard up to expose the LCD screen
    • Be careful when standing up the LCD motherboard to avoid damaging the wires it is connected to.
    • Remove the LCD screen.
3 autres ont terminé cette réparation.
Oneika White
Membre depuis le 10/01/15
709 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 1-4, Leahy Fall 2015 Membre de l'équipe USF Tampa, Team 1-4, Leahy Fall 2015
USFT-LEAHY-F15S1G4
4 membres
5 tutoriels rédigés
Un commentaire
I had a similar model, it was different to open but the LCD was showing all 8's, I just reset the same LCD and it worked like new.
Dennis Lima - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 544
