Aller au contenu principal
  1. Unlock the lock marked in red. Unlock the lock marked in red.
    • Unlock the lock marked in red.
  2. Lift up the battery while unlocking the lock Lift up the battery while unlocking the lock Lift up the battery while unlocking the lock
    • Lift up the battery while unlocking the lock
  3. Unscrew the five screws. Unscrew the five screws.
    • Unscrew the five screws.
  4. Slide the plate in the direction of the red arrow Slide the plate in the direction of the red arrow
    • Slide the plate in the direction of the red arrow
  5. Lift up the back panel Lift up the back panel
    • Lift up the back panel
  6. Unscrew the two screws circled in red Unscrew the two screws circled in red
    • Unscrew the two screws circled in red
  7. Press a paper clip in the three places marked in red Lift the keyboard and feel free to put some strength Lift the keyboard and feel free to put some strength
    • Press a paper clip in the three places marked in red
    • Lift the keyboard and feel free to put some strength
  8. Disconnect the three framed connectors in red Disconnect the three framed connectors in red
    • Disconnect the three framed connectors in red
  9. Pull the white drawer in the direction of the arrow to unlock the connector Disconnect the red circled connector
    • Pull the white drawer in the direction of the arrow to unlock the connector
    • Disconnect the red circled connector
  10. Pull the black drawer in the direction of the arrow to unlock the connector Disconnect the red circled connector
    • Pull the black drawer in the direction of the arrow to unlock the connector
  11. Lift the flap that holds the connector circled in red Disconnect the red circled connector Remove the keyboard
    • Lift the flap that holds the connector circled in red
    • Remove the keyboard
To reassemble your device, follow the instructions in reverse order.
5 autres ont terminé cette réparation.
Merci à ces traducteurs :
fr en
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Felice Suglia
Membre depuis le 15/06/2013
23 468 Réputation
195 tutoriels rédigés
3 commentaires
I wish to know whether it’s possible to pry off the key to clean off the contacts. (I spilled coffee on the keyboard).
Fortunately for me, the key was on the edge of the board (the down arrow key). It was stuck on.
I lifted the key up as much as I could and I cleaned it with Deoxit. That did the trick. My keyboard is now working.
Thanks for the steps!
Clem Wang - Réponse
Oops. Spoke too soon. There’s something wrong with the keyboard: the INSERT key (ESC -[2~ ) is stuck. Also, there’s a red light under the keyboard. I’m not sure what that all means…
Clem Wang - Réponse
Great instructions, but for my laptop, step 7 only indicated three of seven places (the other four are the top centre of the keyboard, and the three points symmetrical to the 3 you’ve indacted, on the right hand side of the keyboard).
Josh Greifer - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 11
30 derniers jours : 38
Total : 2,448
