Introduction
If your PDP Afterglow Fener ear pads are damaged, ripped, or worn down, use this guide for replacement instructions. This guide teaches you how to first remove the ear pads so that they can later be replaced. If you want to complete some inner repairs and simply need access to the ear pieces, you too should use this guide: rather than placing on new pads after completion of this guide, begin repairs on exposed ear pieces instead.
Start by removing the right ear pad. Be careful not to pull too hard as it may rip.
Gently tug on the pad until it comes free from the slot, which is marked by the red square.
Un commentaire
The problem is not pulling off the earpad, but putting it on again!
