Introduction
This guide will provide step-by-step instructions for replacing the A, B, X, and Y buttons on the controller.
Ce dont vous avez besoin
Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
Remove the rubber button covers from the A, B, X, and Y buttons.
3 autres ont terminé cette réparation.
3 commentaires
What about removing the Dpad? i really need help.
I’m sorry but, I have to say that the reassembly process is harder than simply ‘follow the instructions in reverse’; if you try and place the half with the buttons, the buttons fall out or end up misaligned ; and if you use the other half, the rubber covers and the tumblers will fall out.
Again, this guild comes off a little too simple, there’s more to it.
the circuit board comes off the other half. You can stack them very easily. You're simply incorrect.
