Aller au contenu principal
PDP Afterglow Wired Xbox 360 Controller Cable Replacement
Ce dont vous avez besoin
  1. PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Case: étape 1, image 1 de 2 PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Case: étape 1, image 2 de 2
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
  2. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: étape 2, image 1 de 1
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
  3. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: étape 3, image 1 de 1
    • Remove the top cover from the bottom and place next to each other.
  4. PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Cable: étape 4, image 1 de 2 PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Cable: étape 4, image 2 de 2
    • Remove the logic board by lifting up on the logic board and pulling out.
  5. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: étape 5, image 1 de 1
    • The cable connects to the logic board with a white connector. Above the right joystick, there are four solder pins labeled GND, VCC, DM, and DP.
  6. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: étape 6, image 1 de 1
    • The soldering iron is very hot and can harm you or the device if used incorrectly.
    • Desolder the four pins.
  7. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: étape 7, image 1 de 1
    • Using your new cable, solder the white connector to the logic board. Be sure to have the cables facing towards the inside of the logic board.
5 autres ont terminé cette réparation.
Jayson Norcross
Membre depuis le 09/17/15
283 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team 3-1, Harley Fall 2015 Membre de l'équipe IUPUI, Team 3-1, Harley Fall 2015
IUPUI-HARLEY-F15S3G1
4 membres
5 tutoriels rédigés
4 commentaires
where can I find a replacement cable to perform this precedure with?
Aaron English - Réponse
yes!! i would like to know too.. i have been searching for long time for that cable
sokratis162 -
Android cable
Wayne -
U can use a old Android cable
Wayne - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 35
Total : 6,792
