Introduction
Caution: This guide includes using a soldering iron and can damage your controller or your hand if not used properly.
Ce dont vous avez besoin
Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
Lift the Logic Board and remove the rumble motors from the base of the controller.
Un commentaire
Where can I purchase just the rumble motors? I'd like to try adding rumble to a PDP Rock Candy controller, which is essentially the same controller as the AfterGlow but in a neon colored shell and no LED lighting. I don't know if they'll actually work but it would be a fun project.
