Introduction
The action buttons should be replaced on your PDP Rematch Advanced controller if they take more effort to press down. If you need to replace any of the action buttons, separate the front housing shell from the motherboard with this guide.
Ce dont vous avez besoin
Orient the controller so the back side is facing you.
Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
