Aller au contenu principal
Pour réparer ensemble - Je crée un compte
PDP Rematch Advanced Back Buttons Replacement
Ce dont vous avez besoin
  1. PDP Rematch Advanced Back Buttons Replacement, Joystick Cover: étape 1, image 1 de 3 PDP Rematch Advanced Back Buttons Replacement, Joystick Cover: étape 1, image 2 de 3 PDP Rematch Advanced Back Buttons Replacement, Joystick Cover: étape 1, image 3 de 3
    • Orient the controller so the back side is facing you.
    • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
  2. PDP Rematch Advanced Back Buttons Replacement: étape 2, image 1 de 3 PDP Rematch Advanced Back Buttons Replacement: étape 2, image 2 de 3 PDP Rematch Advanced Back Buttons Replacement: étape 2, image 3 de 3
    • Pull apart the controller's front and back shells with moderate force.
    • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
  3. PDP Rematch Advanced Back Buttons Replacement: étape 3, image 1 de 2 PDP Rematch Advanced Back Buttons Replacement: étape 3, image 2 de 2
    • Twist the thumbstick to remove it from the motherboard. Repeat this step if both thumbsticks need to be replaced.
  4. PDP Rematch Advanced Back Buttons Replacement, Back Shell: étape 4, image 1 de 2 PDP Rematch Advanced Back Buttons Replacement, Back Shell: étape 4, image 2 de 2
    • Grab the motor and pull away from the back shell. Repeat for both motors.
  5. PDP Rematch Advanced Back Buttons Replacement: étape 5, image 1 de 2 PDP Rematch Advanced Back Buttons Replacement: étape 5, image 2 de 2
    • Use a Phillips #00 Screwdriver to remove the two 5mm screws from the motherboard.
  6. PDP Rematch Advanced Back Buttons Replacement: étape 6, image 1 de 3 PDP Rematch Advanced Back Buttons Replacement: étape 6, image 2 de 3 PDP Rematch Advanced Back Buttons Replacement: étape 6, image 3 de 3
    • Remove the motherboard from the back shell using moderate force.
  7. PDP Rematch Advanced Back Buttons Replacement, Back Buttons: étape 7, image 1 de 2 PDP Rematch Advanced Back Buttons Replacement, Back Buttons: étape 7, image 2 de 2
    • Use a Phillips #00 to remove the two 5mm screws from the back buttons.
  8. PDP Rematch Advanced Back Buttons Replacement: étape 8, image 1 de 3 PDP Rematch Advanced Back Buttons Replacement: étape 8, image 2 de 3 PDP Rematch Advanced Back Buttons Replacement: étape 8, image 3 de 3
    • Lift the back button, and then pull it out through the back shell. Do this for both back buttons.
Collin Lawe
Membre depuis le 10/02/23
462 Réputation
3 tutoriels rédigés
Équipe
Utah Tech University, Team 1-1, McMurrin Spring 2024 Membre de l'équipe Utah Tech University, Team 1-1, McMurrin Spring 2024
UTAHTECH-MCMURRIN-S24S1G1
2 membres
7 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 18
30 derniers jours : 49
Total : 614
