Aller au contenu principal
PDP Rematch Advanced Trigger Springs Replacement
Ce dont vous avez besoin
  1. PDP Rematch Advanced Trigger Springs Replacement, Trigger Springs: étape 1, image 1 de 2 PDP Rematch Advanced Trigger Springs Replacement, Trigger Springs: étape 1, image 2 de 2
    • Orient the controller so the back side is facing you.
    • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
  2. PDP Rematch Advanced Trigger Springs Replacement: étape 2, image 1 de 3 PDP Rematch Advanced Trigger Springs Replacement: étape 2, image 2 de 3 PDP Rematch Advanced Trigger Springs Replacement: étape 2, image 3 de 3
    • Pull apart the controller's front and back shells with moderate force.
    • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
  3. PDP Rematch Advanced Trigger Springs Replacement: étape 3, image 1 de 2 PDP Rematch Advanced Trigger Springs Replacement: étape 3, image 2 de 2
    • Twist the thumbstick to remove it from the motherboard.
  4. PDP Rematch Advanced Trigger Springs Replacement: étape 4, image 1 de 3 PDP Rematch Advanced Trigger Springs Replacement: étape 4, image 2 de 3 PDP Rematch Advanced Trigger Springs Replacement: étape 4, image 3 de 3
    • Use a Phillips #000 screwdriver to remove the two 5 mm screws that secure the motherboard.
    • Remove the motherboard from the back shell using moderate force.
  5. PDP Rematch Advanced Trigger Springs Replacement: étape 5, image 1 de 3 PDP Rematch Advanced Trigger Springs Replacement: étape 5, image 2 de 3 PDP Rematch Advanced Trigger Springs Replacement: étape 5, image 3 de 3
    • Punch out the metal pin holding in the trigger and the trigger spring. Repeat for both triggers.
    • Remove the trigger and the trigger springs.
    • Using a punch or a small tool allows pin removal to be easier.
Jacob Thomas Wolgamott
Membre depuis le 09/23/24
121 Réputation
1 tutoriel rédigé
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 20
Total : 321
