Aller au contenu principal
PS4 Dualshock 4 trigger reassembly
Ce dont vous avez besoin
  1. PS4 Dualshock 4 trigger reassembly, Preparing the triggers: étape 1, image 1 de 2 PS4 Dualshock 4 trigger reassembly, Preparing the triggers: étape 1, image 2 de 2
    • Remove these two triggers and springs from the backplate.
    • Find which trigger goes on which side and put the springs in the trigger part facing towards the inside of the controller.
  2. PS4 Dualshock 4 trigger reassembly, Attaching the triggers.: étape 2, image 1 de 2 PS4 Dualshock 4 trigger reassembly, Attaching the triggers.: étape 2, image 2 de 2
    • On these two clips...
    • Push down the trigger until it clicks on both sides.
    • Make sure that the one spring part is inside the rail (marked cyan) and the other outside the whole assembly (green).
  3. PS4 Dualshock 4 trigger reassembly, Connecting the light bar: étape 3, image 1 de 1
    • Connect the light bar cable using your fingers. Make sure it is fully pushed down and that is plugged in the right way.
  4. PS4 Dualshock 4 trigger reassembly, Closing the cover: étape 4, image 1 de 2 PS4 Dualshock 4 trigger reassembly, Closing the cover: étape 4, image 2 de 2
    • close the cover starting from the side of the triggers. Don't worry if it's a bit hard to do so, but be careful so you don't break the plastic between the trigger and the bumper.
    • Push down until it clicks everywhere.
    • Finally, screw in these four screws using a PH0 screwdriver.
Ligne d'arrivée
23 autres ont terminé cette réparation.
Devnol
Membre depuis le 12/01/18
2 684 Réputation
5 tutoriels rédigés
3 commentaires
Thank you so much! I had a ps4 controller that had a broken r2 button and i had gotten a replacement (which is now having battery issues) Today I took the old controller apart… the spring had come out of the rail. That was it!
Dee - Réponse
This guide is wrong. The top part spring should be inside the trigger, if you look at the other trigger it’s not exposed.
https://pureplaystation.com/wp-content/u...
Angus Yung - Réponse
Thanks for pointing it out. I do not have this controller anymore as it was from a repair job so unfortunately, I cannot correct it. If you or someone else happens to have one and is able to take high-quality pictures I’d be more than grateful to accept your correction.
Devnol -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 92
30 derniers jours : 494
Total : 39,710
