Introduction
Use this guide to replace the joystick covers on your controller.
Ce dont vous avez besoin
Remove the two 10 mm Phillips #1 screws that secure each of the handle grips.
Pull off the handle grips.
Use blunt tweezers to pull the white battery motherboard connector directly out of its port.
Gently peel the battery off of the motherboard.
Remove the two 7 mm Phillips #1 screws that secure the motherboard.
Presque terminé !
