Aller au contenu principal
PSP 1000 Motherboard Replacement
Ce dont vous avez besoin
  1. PSP 1000 Motherboard Replacement, Motherboard: étape 1, image 1 de 2 PSP 1000 Motherboard Replacement, Motherboard: étape 1, image 2 de 2
    • Remove any external cables from the device and place the device face down on a flat surface.
  2. PSP 1000 Motherboard Replacement: étape 2, image 1 de 2 PSP 1000 Motherboard Replacement: étape 2, image 2 de 2
    • Remove the battery door cover located on the left hand side.
    • Remove the battery from the device.
  3. PSP 1000 Motherboard Replacement: étape 3, image 1 de 1
    • Using a flat tool, remove the warranty sticker. Removing this sticker will expose two screws.
  4. PSP 1000 Motherboard Replacement: étape 4, image 1 de 3 PSP 1000 Motherboard Replacement: étape 4, image 2 de 3 PSP 1000 Motherboard Replacement: étape 4, image 3 de 3
    • Using a Phillips #00 screwdriver, remove the two black 5.2 mm screws marked in red.
    • Remove the two silver 2.4 mm screws marked in orange.
    • Remove the silver 4.4 mm screw marked in yellow at the bottom of the case.
    • Remove the two black 5.4 mm screws marked in green on the back of the case.
  5. PSP 1000 Motherboard Replacement: étape 5, image 1 de 3 PSP 1000 Motherboard Replacement: étape 5, image 2 de 3 PSP 1000 Motherboard Replacement: étape 5, image 3 de 3
    • Use a plastic opening tool to gently pry the face plate off of the device.
    • Be gentle when prying the face plate as you do not want to crack or scratch it.
  6. PSP 1000 Motherboard Replacement: étape 6, image 1 de 3 PSP 1000 Motherboard Replacement: étape 6, image 2 de 3 PSP 1000 Motherboard Replacement: étape 6, image 3 de 3
    • Remove the top left and right trigger buttons by simply pulling them out.
  7. PSP 1000 Motherboard Replacement: étape 7, image 1 de 2 PSP 1000 Motherboard Replacement: étape 7, image 2 de 2
    • Using a plastic opening tool, lift the left side of the bottom circuit that includes the home, start, pause, and volume buttons.
  8. PSP 1000 Motherboard Replacement: étape 8, image 1 de 1
    • Disconnect the zero-insertion force (ZIF) connector by unlocking the locking tab with a plastic opening tool.
  9. PSP 1000 Motherboard Replacement: étape 9, image 1 de 3 PSP 1000 Motherboard Replacement: étape 9, image 2 de 3 PSP 1000 Motherboard Replacement: étape 9, image 3 de 3
    • Using a plastic opening tool, lift the LCD screen from in between the metal brackets.
    • Start at the bottom of the screen for an efficient removal.
    • Be very careful as the screen is very fragile.
  10. PSP 1000 Motherboard Replacement: étape 10, image 1 de 3 PSP 1000 Motherboard Replacement: étape 10, image 2 de 3 PSP 1000 Motherboard Replacement: étape 10, image 3 de 3
    • Use the plastic opening tool to unlock all the ribbon cables attached from the LCD screen to the motherboard.
  11. PSP 1000 Motherboard Replacement: étape 11, image 1 de 3 PSP 1000 Motherboard Replacement: étape 11, image 2 de 3 PSP 1000 Motherboard Replacement: étape 11, image 3 de 3
    • Using the Phillips #00 screwdriver, remove the two silver 4.2mm screws marked in red.
    • Remove the three silver 3mm screws marked in orange.
    • Remove the black 4.2mm screw marked in yellow.
  12. PSP 1000 Motherboard Replacement: étape 12, image 1 de 2 PSP 1000 Motherboard Replacement: étape 12, image 2 de 2
    • Once all screws are removed, gently lift the metal cage from the bottom.
    • If there is resistance, slide the open button on top of the device as it may be latched to the cage.
  13. PSP 1000 Motherboard Replacement: étape 13, image 1 de 3 PSP 1000 Motherboard Replacement: étape 13, image 2 de 3 PSP 1000 Motherboard Replacement: étape 13, image 3 de 3
    • Remove the single 4.4mm screw that holds the D-Pad in place using the Phillips #00 screwdriver.
    • Underneath the D-Pad, unlock the ZIF connector holding the ribbon cable in place using the plastic opening tool.
  14. PSP 1000 Motherboard Replacement: étape 14, image 1 de 3 PSP 1000 Motherboard Replacement: étape 14, image 2 de 3 PSP 1000 Motherboard Replacement: étape 14, image 3 de 3
    • Using a plastic opening tool, unlock the small black clip that is located underneath the circuit board.
  15. PSP 1000 Motherboard Replacement: étape 15, image 1 de 3 PSP 1000 Motherboard Replacement: étape 15, image 2 de 3 PSP 1000 Motherboard Replacement: étape 15, image 3 de 3
    • Using a plastic opening tool, remove the steel bracket under the right trigger.
  16. PSP 1000 Motherboard Replacement: étape 16, image 1 de 2 PSP 1000 Motherboard Replacement: étape 16, image 2 de 2
    • Use the plastic opening tool to unlock all of the ZIF connectors and disconnect all cables from the motherboard.
  17. PSP 1000 Motherboard Replacement: étape 17, image 1 de 3 PSP 1000 Motherboard Replacement: étape 17, image 2 de 3 PSP 1000 Motherboard Replacement: étape 17, image 3 de 3
    • Using a plastic opening tool, unclip the cable from the circuit and begin to remove any tape securing any cables.
    • Remove the single 1.5 mm screw on the bottom right of the power input using the Phillips #00 screwdriver to remove the cable.
  18. PSP 1000 Motherboard Replacement: étape 18, image 1 de 3 PSP 1000 Motherboard Replacement: étape 18, image 2 de 3 PSP 1000 Motherboard Replacement: étape 18, image 3 de 3
    • Above the charging input cable is the wireless antenna. Gently lift and place the wireless antenna on the left-hand side as it cannot be completely removed.
  19. PSP 1000 Motherboard Replacement: étape 19, image 1 de 3 PSP 1000 Motherboard Replacement: étape 19, image 2 de 3 PSP 1000 Motherboard Replacement: étape 19, image 3 de 3
    • Remove the speaker cables highlighted on the bottom middle by removing any tape.
    • Using a flat tool unclip the cables from the motherboard along with the ribbon cable on the right.
  20. PSP 1000 Motherboard Replacement: étape 20, image 1 de 3 PSP 1000 Motherboard Replacement: étape 20, image 2 de 3 PSP 1000 Motherboard Replacement: étape 20, image 3 de 3
    • Using your fingers or a plastic opening tool, slide the UMD drive ribbon cable from the lock to release it.
  21. PSP 1000 Motherboard Replacement: étape 21, image 1 de 3 PSP 1000 Motherboard Replacement: étape 21, image 2 de 3 PSP 1000 Motherboard Replacement: étape 21, image 3 de 3
    • Using the Phillips #00 screwdriver, remove the single 4.4 mm screw located on the top right of the motherboard.
  22. PSP 1000 Motherboard Replacement: étape 22, image 1 de 3 PSP 1000 Motherboard Replacement: étape 22, image 2 de 3 PSP 1000 Motherboard Replacement: étape 22, image 3 de 3
    • Gently lift the motherboard up and away to remove it from the device.
    • Carefully and slowly remove the motherboard as you do not want to damage anything caught onto the board.
5 autres ont terminé cette réparation.
Faraz Rashid
Membre depuis le 05/10/21
461 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G26, Melo-Thaiss Summer 2021 Membre de l'équipe York University, Team S1-G26, Melo-Thaiss Summer 2021
YORK-MELO-THAISS-SU21S1G26
1 membre
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 13
7 derniers jours : 58
30 derniers jours : 368
Total : 8,947
