Introduction
In this guide I will be going through a detailed step by step process on how to replace your PSP 1000 motherboard. There is no prior experience required in order to begin this replacement as it is very short and simple. The PSP 1000 was first released in 2005 and as many years have passed this device has aged poorly. The main purpose for this guide is to replace a damaged or time worn motherboard that needs replacing as the device itself is ahead of its time, yet the parts have aged 16 years. Have an empty desk along with the tools required for an easy and simple breakdown of your device. Thoroughly read the steps and operate on your device with the specified tools.
Ce dont vous avez besoin
Remove any external cables from the device and place the device face down on a flat surface.
Using a Phillips #00 screwdriver, remove the two black 5.2 mm screws marked in red.
Remove the two silver 2.4 mm screws marked in orange.
Remove the silver 4.4 mm screw marked in yellow at the bottom of the case.
Remove the two black 5.4 mm screws marked in green on the back of the case.
5 autres ont terminé cette réparation.
