Aller au contenu principal
PSP 1000 Speakers Replacement
Ce dont vous avez besoin
  1. PSP 1000 Speakers Replacement, Battery: étape 1, image 1 de 1
    • Turn the PSP over so its back is facing you.
  2. PSP 1000 Speakers Replacement: étape 2, image 1 de 2 PSP 1000 Speakers Replacement: étape 2, image 2 de 2
    • Locate the battery casing button on the rear-left side of the PSP.
    • Press down the button and remove the battery cover.
  3. PSP 1000 Speakers Replacement: étape 3, image 1 de 2 PSP 1000 Speakers Replacement: étape 3, image 2 de 2
    • Using your finger, remove the battery upwards from the system as shown.
  4. PSP 1000 Speakers Replacement, Front Casing: étape 4, image 1 de 2 PSP 1000 Speakers Replacement, Front Casing: étape 4, image 2 de 2
    • Remove the four screws shown with a Phillips #00 screwdriver.
    • You will have to peel back the guarantee sticker to access the screw on the lower left.
  5. PSP 1000 Speakers Replacement: étape 5, image 1 de 1
    • Remove the screw from the bottom side of the PSP. Keep it separated from the rest of the screws.
    • Remove screws from back righthand side within the holes.
  6. PSP 1000 Speakers Replacement: étape 6, image 1 de 2 PSP 1000 Speakers Replacement: étape 6, image 2 de 2
    • Gently separate the outer plastic casing from the rest of the system as shown.
  7. PSP 1000 Speakers Replacement, LCD Screen: étape 7, image 1 de 1
    • The Button Board, at the base of the LCD Screen, is held by two clips.
    • Pry these clips over the nubs using a PSP opening tool. This will release the clips.
    • The Button Board is still attatched to the PSP by a ribbon cable!
  8. PSP 1000 Speakers Replacement: étape 8, image 1 de 3 PSP 1000 Speakers Replacement: étape 8, image 2 de 3 PSP 1000 Speakers Replacement: étape 8, image 3 de 3
    • The Button Board Ribbon Cable is held down with a latch. Lift the latch open, away from the ribbon cable.
    • Pull the cable away from the latch.
  9. PSP 1000 Speakers Replacement: étape 9, image 1 de 2 PSP 1000 Speakers Replacement: étape 9, image 2 de 2
    • The LCD Screen is held by the LCD Frame with similar clips. Slide a thin tool between the clip and the screen and gently pry them apart while beginning to lift the screen.
  10. PSP 1000 Speakers Replacement: étape 10, image 1 de 1
    • The LCD screen is still attached with ribbon cables. Gently lift up the LCD screen so you do not break them.
  11. PSP 1000 Speakers Replacement: étape 11, image 1 de 3 PSP 1000 Speakers Replacement: étape 11, image 2 de 3 PSP 1000 Speakers Replacement: étape 11, image 3 de 3
    • The thin Ribbon Cable opens from the opposite side in which the Ribbon Cable enters. Open up the latch towards the Ribbon Cable. The latch will pull up and release the ribbon cable. Put your tool behind the black part, then pry up the black piece of plastic.
    • The wide Ribbon Cable opens from the same side in which the Ribbon Cable attatches, and opens away from the cable.
    • Both of these latches are the black pieces.
    • Gently pull the ribbon cables away from the latches. The LCD screen can now be removed.
    • When reassembling - be careful which way you push the latches. The small one is very easy to break.
  12. PSP 1000 Speakers Replacement, Speakers: étape 12, image 1 de 1
    • Remove the screws on the top and bottom of the frame. Be sure to keep track of where you took each screw out of.
  13. PSP 1000 Speakers Replacement: étape 13, image 1 de 1
    • After the screws are removed, the bottom of the LCD frame will rise.
    • Open up the UMD Drive, and then slide the top of the LCD frame slightly to the right while pulling out.
  14. PSP 1000 Speakers Replacement: étape 14, image 1 de 1
    • The speakers will now be exposed.
  15. PSP 1000 Speakers Replacement: étape 15, image 1 de 2 PSP 1000 Speakers Replacement: étape 15, image 2 de 2
    • The speakers should slide out fairly easily; it may be helpful to use tweezers to begin prying them out.
  16. PSP 1000 Speakers Replacement: étape 16, image 1 de 3 PSP 1000 Speakers Replacement: étape 16, image 2 de 3 PSP 1000 Speakers Replacement: étape 16, image 3 de 3
    • Gently unplug the speakers from the socket. The speakers are completely detatched when they are unplugged from the logic board.
9 autres ont terminé cette réparation.
Chris
Membre depuis le 01/14/10
1 936 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 5-6, Forte Winter 2010 Membre de l'équipe Cal Poly, Team 5-6, Forte Winter 2010
CPSU-FORTE-W10S5G6
5 membres
22 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 30
30 derniers jours : 110
Total : 24,958
