Introduction
Has the UMD door on your PSP 3000c seen better days? Follow this guide to replace it with a shiny new door.
Ce dont vous avez besoin
Press the button securing the battery door to the PSP 300xc, and lift the battery door off.
Lift the battery out of the PSP.
Use a spudger or your fingernail to remove the warranty sticker stuck to the inside of the battery tray
Rotate the LCD away from the PSP to reveal the LCD and home bar ribbon cables.
Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following four ZIF connectors:
Home bar cable
Microphone cable
LCD display data cable
Touchscreen cable
After flipping up the locking tabs on all four connectors, use your fingers or a spudger to gently pull the cables straight out of the connectors.
Lift the home bar up as high as it will go, but not so high that the wires disconnect.
Twist the home bar counter clockwise while carefully lifting it further. The left edge has to lift over the black plastic frame to allow it to rotate.
The home bar should now lift out of the PSP 300xc.
Using the flat edge of a spudger, pry the power board away from the PSP 300xc.
Use your fingernail or the edge of a spudger to flip up the retaining flap on the UMD drive ribbon socket.
Use your fingernail or tip of a spudger to push both sides of the black retaining flap on the UMD laser ribbon socket to the right.
Use a spudger to gently pull both ribbon cables straight out of their sockets.
Flip the PSP 300xc over and open the UMD door.
Using a pair of tweezers, grab the small rubber square between the metal UMD brace and case, and lift it out of the PSP 300xc.
Repeat for the rubber square on the other side of the UMD door.
Bend the PSP 300xc case while pulling up on the right edge of the UMD door until the right edge lifts free.
Remove the UMD door.
2 autres ont terminé cette réparation.
