Aller au contenu principal
Introduction
PSP E1000 / E1004
not read UMD games and you haven't indication for insertion games. The problem probably is in UMD switch.
You can see the video:
Vidéo d'introduction
  1. If you haven't indication for inserted disk the problem probably is in UMD switch. If you haven't indication for inserted disk the problem probably is in UMD switch. If you haven't indication for inserted disk the problem probably is in UMD switch.
    • If you haven't indication for inserted disk the problem probably is in UMD switch.
  2. Unhook the door metal plate and disassemble UMD door. Unhook the door metal plate and disassemble UMD door. Unhook the door metal plate and disassemble UMD door.
    • Unhook the door metal plate and disassemble UMD door.
  3. With a screwdriver I short the UMD switch to test the laser. With a screwdriver I short the UMD switch to test the laser.
    • With a screwdriver I short the UMD switch to test the laser.
  4. Now let's disassemble it. Now let's disassemble it. Now let's disassemble it.
    • Now let's disassemble it.
  5. Fix Kits pour batterie de MacBook
    À partir de $69.99
    Buy Now
    À partir de $69.99
    Buy Now
  6. Disconnect and remove the display. Disconnect and remove the display. Disconnect and remove the display.
    • Disconnect and remove the display.
  7. I must disconnect 7x cables and unscrew a screw. I must disconnect 7x cables and unscrew a screw.
    • I must disconnect 7x cables and unscrew a screw.
  8. Now I disconnect the battery connector and here is the mainboard. Now I disconnect the battery connector and here is the mainboard. Now I disconnect the battery connector and here is the mainboard.
    • Now I disconnect the battery connector and here is the mainboard.
  9. I used soldering station to remove the old one and put the new one (UMD switch). I used soldering station to remove the old one and put the new one (UMD switch).
    • I used soldering station to remove the old one and put the new one (UMD switch).
  10. Let's assemble and test it. Let's assemble and test it. Let's assemble and test it.
    • Let's assemble and test it.
  11. And it works!
    • And it works!
3 autre(s) ont terminé cette réparation.
ZFix
Membre depuis le 09/12/2013
164 077 Réputation
305 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
286 membres
808 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 5
7 derniers jours : 11
30 derniers jours : 81
Total : 5,689
