Aller au contenu principal
Pac-Man Connect and Play Joystick Switchboard Replacement
Ce dont vous avez besoin
  1. Pac-Man Connect and Play Joystick Switchboard Replacement, Joystick Switchboard: étape 1, image 1 de 2 Pac-Man Connect and Play Joystick Switchboard Replacement, Joystick Switchboard: étape 1, image 2 de 2
    • Flip over the device
    • Ensure the device has no power and is not plugged into a TV
  2. Pac-Man Connect and Play Joystick Switchboard Replacement: étape 2, image 1 de 1
    • Remove these 5 Phillips Head screws
  3. Pac-Man Connect and Play Joystick Switchboard Replacement: étape 3, image 1 de 2 Pac-Man Connect and Play Joystick Switchboard Replacement: étape 3, image 2 de 2
    • You can now open the device
  4. Pac-Man Connect and Play Joystick Switchboard Replacement: étape 4, image 1 de 1
    • Remove these 2 screws (phillips)
  5. Pac-Man Connect and Play Joystick Switchboard Replacement: étape 5, image 1 de 3 Pac-Man Connect and Play Joystick Switchboard Replacement: étape 5, image 2 de 3 Pac-Man Connect and Play Joystick Switchboard Replacement: étape 5, image 3 de 3
    • You can now remove the board
    • You can, at this time, also remove the plastic X that holds the joystick spring in place.
9021007
Membre depuis le 07/13/18
4 599 Réputation
25 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 12
Total : 533
